Scanning to wifi connected network pc
  • star38
    • Jun 2009
    • 8
    Appreciate if someone advise me, the scanned document from network (wired) scanner is not reaching to the PC connected through Wi-Fi (same network).
    Thanks in advance.
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: Scanning to wifi connected network pc
    Thanks in advance.
    And you've tried .................................................. .
    Using this O/S................................................. ......
    On this MFD............................................... ...........
    Current state ATM .................................................
    Hint: Fill in the above blanks for us.
      Thanks in advance.
      did you specify that destination?
      what are the IP schemes for all?
      error codes/messages?
      what type doc?
      WHAT MACHINE?
      what speed network?
      WAY more information needed!!!
      PhilB " The Dentist"
      • COPIERMAN
        • Jun 2009
        • 559
        the copier works on the 2g side of router not the 5 g. check your wifi make sure you connect on 2g side.
        • star38
          • Jun 2009
          • 8
          Please, thr copier is connected to the port with wire (wired nW) but the pc is on Wi-Fi.
          • star38
            • Jun 2009
            • 8
            Thanks for your reply,
            did you specify that destination? - Yes
            error codes/messages? - No
            what type doc? - ???
            WHAT MACHINE? sharp MFD
            what speed network? - 1000t
            • star38
              • Jun 2009
              • 8
              Using this O/S window 7 & 10................................................ .......
              On this MFD Sharp - MX-4140N............................................. .............
              Current state ATM ???............................................... ..
              • copier tech
                • 8165
                The short answer is yes this is possible, most copiers are wired & laptops wifi, SMB scan works fine in this setup.
                As a test plug a laptop into a wired port, now does SMB scan work?
                • NeoMatrix
                  Senior Tech.
                  • 3513
                  Further........
                  The PC is not using Airprint. Airprint sets up its own individual network.
                  The router is not set for "individual WiFi connections" otherwise the MFD or PC will only see the WAN an not LAN.
                  All resources/shares must have access to the LAN to be able to see each other. Make sure they're on the same subnet.
                  A simple xping batch file to find IP's connected to a given network/subnet:
                  hhttp://www.copytechnet.com/forums/connectivity/97276-all-one-i-t-tech-software-post730769.html#post730769
                  All in one I.T. Tech software.
                  • qbert69
                    • Mar 2013
                    • 1152
                    Is the PC on password protected Wi-Fi or guest wifi, plus is the PC network location set to public or private???[emoji848]
                    Sent from my SM-N950U1 using Tapatalk
                    REACH FOR THE STARS!!!
                    Konica Minolta Planetariums!
                      • 37518
                      Is the PC using an internal WiFi or a USB WiFi dongle? I have encountered USB WiFi dongle that do not support file sharing.
