Speed up printing help
  • stan780953
    • Feb 2011
    • 47
    Hi All,
    When printing CAD drawings from Draftsight to a Konica Minolta C284 it can sometimes take up to 20 minutes before the document will print, the document will spool and leave the queue while the KM's data flashes but it will take a while before anything appears in the job list. The document I am using to test does have a lot going on in terms of layers but surely it shouldn't take this long.
    I've tried a PCL/PS driver, changed Download Font Format to Bitmap, disabled SNMP Status, disabled Advanced Printing Features & enabled Print Directly to the Printer to no avail.
    Any help would be much appreciated.
  • copier tech
    • 8144
    Re: Speed up printing help
    Try using the "print as image setting" this can help.
    Also what version of firmware is the machine on?
    C224 is an old model now.
    • gerryproulx
      • Mar 2015
      • 24
      I would try printing from the web page to bypass the driver or try printing from a USB to bypass the network to see where the slow down is occurring I would suspect it is the CAD program though turn on print after last page is spooled and see when the light comes on at the c284 that would be the processing time
      • guitar9199
        • Sep 2016
        • 1100
        +1 on the "Print As Image". Some of those CAD files have so many layers in them, and most print drivers will process each layer one at a time before printing. Print As Image knocks everything down to one layer.
        PostScript is very slow too.... I'd use strictly PCL unless you're using a Mac.
          +2 Print As Image
          • srvctec
            Former KM Senior Tech
            • Oct 2009
            • 827
            I made this up to hand out to customers and to refer to myself for speeding up printing. I got most of this info from several places here on CTN.Speed Up Printing.pdf
            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
              • 30219
              Originally posted by srvctec
              I made this up to hand out to customers and to refer to myself for speeding up printing. I got most of this info from several places here on CTN.[ATTACH]43147[/ATTACH]
              This is NUTs Byte count slooooows the print job way down
              I would only use lpr to print to a fiery Not the standard. raw 9100
              Most cases slow printing is due to wrong driver, port settings never use WSD ports
              • stan780953
                • Feb 2011
                • 47
                Thank you for your help.
                I have tried exporting as a PDF and using Print As Image is definitely the way forward, however, the customer wants to print directly from the application but having tried all suggestions I don't think this is going to be possible.
                • Kimi
                  • Feb 2018
                  • 105
                  Pause the print queue and send the job, try to demonstrate to the customer the size of file impacts the speed/time of printing.
                  • srvctec
                    • Oct 2009
                    • 827
                    Hmmmm, that's funny. EVERYWHERE I've done this, printing is sped up considerably. Guess I just have the magic touch or something.
                    • allan
                      RTFM!!
                      • 5462
                      Print to PDF and time that.
                      Whatever
