365 & Webdav
  • kingarthur
    • 1350
    365 & Webdav
    Hi
    got a customer using webdav & papercut, has just migrated to 365, when they scan through webdav it says job completed, but it doesn't appear anywhere
    is there anything special that needs to be set up to scan to 365 using webdav
    cheers
  • BaconSteve
    • Apr 2019
    • 140
    Re: 365 & Webdav
    Holy smokes, The Perfect Storm.
      • 8193
      Re: 365 & Webdav
      You are going to have to check with your copier manufacturer first to determine the best technical resources to find a solution.
      This is definitely 3rd party billable Professional service hours and the solution is not within the toolbox of a typical copier dealer. By this I mean, someone is going to invoice you to try and find a solution and you will pass that invoice onto the customer plus the cost of your time. A solution is not necessarily guaranteed nor inexpensive.
      With three different technologies all inplace at one time, you are going to have a hard time finding the correct expert. I would start with Papercut.
      Customer's often lock onto new technology without first checking within anyone if it is possible to support.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Re: 365 & Webdav
        The stuff nightmares are made of.
        • kingarthur
          • 1350
          Re: 365 & Webdav
          Knew this wasn't going to be an easy one, I tried scanning without the webdav, used direct input and manually entered the email address,(set up SMTP with office 365 credentials) got a login error, network code 550, got the customer to double check their password, also got them to change password as it was a new 365 account set up for scanner
            • 8193
            Re: 365 & Webdav
            WebDAV is a form of cloud storage. Office 365 OneDrive for Business is a form of Cloud Storage.
            Is the issue that scan to Office 365 Outlook email accounts do not work?
            Or are you saying that somehow you scan into WebDAV folders via email?
            Can you scan to WebDAV or OneDrive for Business? Does the customer not want to migrate their WebDAV folders to OneDrive for Business (if that is even technically possible)?
            What is the model # of copier you are working with? Does it offer an Office 365 app?
            • kingarthur
              • 1350
              Re: 365 & Webdav
              I've never seem WebDAV in action before, it seems that when they login in to papercut, they select WebDAV and this appears to send to their 365 email account, they have 4 different models, but are trying to sort it on the KM bizhub C308
              They are now, apparently, getting an error message from papercut saying "There seems to be a problem sending your scanned document" then is has the file details, persons name name,date & file type, followed by "if this problem persists please contact your administrator", so the client thinks it's a papercut issue
                • 8193
                Re: 365 & Webdav
                I would start by engaging Konica Minolta's "All Covered" IT Division for Professional Services.
                If the customer has a Papercut service contract you could start there as well.
                • Kimi
                  • Feb 2018
                  • 105
                  Re: 365 & Webdav
                  Try setting up scan to email rather than webdav?
                  We have clients with KMs/solutions and i only remember them using scan to email/folder.
                    • 37480
                    Re: 365 & Webdav
                    Should work as long as you MFP supports TLS/StartTLS. If not, a relay server will be required. A number of national IT company provide relay services for their customers. Another option is a local relay software such as Stunnel.
                    • kingarthur
                      • 1350
                      Re: 365 & Webdav
                      Well...I've learnt something, Papercut has it's own SMTP settings, that's where you put the 365 settings....
                      • Kimi
                        • Feb 2018
                        • 105
                        Re: 365 & Webdav
                        everyday is a school day!
                        • kingarthur
                          • 1350
                          Re: 365 & Webdav
                          especially when it comes to networks & papercut, i'm learning all the time
