Safecom
  • kingarthur
    • 1318
    Safecom
    Has anybody encountered CMS Validity Check Error(3) when adding a KM C458e device to Safecom, the customer has upgraded to the latest version of Safecom server, they currently have a couple of C454es on the server, which are working fine, a couple have been removed, all the settings on the device look fine, a new certificate has been generated on each device, can't find what the code means anywhere.
  • Kimi
    • Feb 2018
    • 105
    Re: Safecom
    Yes all the time and it usually comes down to firmware levels on the device.
    If i remember there is a workaround - when adding it to the DS set open api to true.
    • kingarthur
      • 1318
      Re: Safecom
      I was wondering about the FW, they've all got the latest FW, but on a previous occasion when I had to install a C458, I had to roll back the FW, so I'll give it a try
      Cheers
      • cube10025@gmail.com
        • Aug 2022
        • 55
        Re: Safecom
        Open API?
