Ricoh MP301
  • digicor
    • Jul 2008
    • 1134
    Ricoh MP301
    Machine was working pefectly, clien had a router go down, new router put in office, print, is fine, he has internet and email, yet, the email scan wont work from the machine, its says "standby"
    i have the ports open in the router, its not a different company.... anyone have this issue?
  • guitar9199
    • Sep 2016
    • 1097
    Re: Ricoh MP301
    What email address are they using for send? If it's gmail or something like that, it MAY be seeing the new router as email coming from a DIFFERENT location. You might need to log into the email interface to "approve" email coming from the new location....even though it's the same machine/place/etc.
    • digicor
      • Jul 2008
      • 1134
      Re: Ricoh MP301
      do you mean the email interface on the web access? or the router?
      i have frontier on the phone and we went through every thing that could possibly be changed... no luck
      the web interface?on the mp301? change what if you will explain please?
      • FrohnB
        • Jul 2017
        • 1919
        Re: Ricoh MP301
        Did the new router change any of the IP settings? Maybe a conflict somewhere?
        Did you cycle the machine? From time to time it has done the trick for me.
        Login into the Gmail account that was set up for scanning. Send a scan, and if I remember correctly there should be a message in the email to allow or something like that. Could be wrong though. Guitar9199 might be able to clarify more.
        Login to Web interface (as admin), click configuration, go to "File Transfer" and re-input the FTP username and password. Then go to "Email" and input the SMTP info (email addresses/ username/ password).
        Do you have any DNS servers set? We like to use 8.8.8.8 and 8.8.4.4
        Under Security, there is "access control", make sure you don't have any of these set, unless it's needed.
        Omertà
        • digicor
          • Jul 2008
          • 1134
          Re: Ricoh MP301
          Originally posted by FrohnB
          Did the new router change any of the IP settings? Maybe a conflict somewhere? no
          Did you cycle the machine? From time to time it has done the trick for me. yes
          im not using gmail, im using my roadrunner account, spectrum, i have it set up on over 100 clients, it works..
          Login into the Gmail account that was set up for scanning. Send a scan, and if I remember correctly there should be a message in the email to allow or something like that. Could be wrong though. Guitar9199 might be able to clarify more. /Na
          Login to Web interface (as admin), click configuration, go to "File Transfer" and re-input the FTP username and password. Then go to "Email" and input the SMTP info (email addresses/ username/ password). ill give this a retry
          Do you have any DNS servers set? We like to use 8.8.8.8 and 8.8.4.4 yes on this and i have tried all "0" and the gate way 192.168.1.1
          none of this is set
          • guitar9199
            • Sep 2016
            • 1097
            Re: Ricoh MP301
            The Router only provides internet access.... it won't have anything to do with the email, other than maybe providing a DIFFERENT IP address than the mail server is used to seeing.
            If the email server (smtp.gmail.com for example) is used to seeing email being sent from one IP address, then suddenly that address changes, it MIGHT think your email is being hacked. Log into your email using a web browser, and see if it sent you any messages asking "Is this you"?
            • oldtech
              • 83
              Re: Ricoh MP301
              I'll bet DNS is broken somewhere.
              Can't remember if you can test name server connections at the panel on the MP301 or not.
              Let us know what the fix is...
