imac restore help!
  • copier tech
    • 8133
    imac restore help!
    Command+R
    Holding C
    Holding CMD
    None of these do anything.
    Any idea where to go next?
  • qbert69
    • Mar 2013
    • 1152
    Re: imac restore help!
    Command+R
    Holding C
    Holding CMD
    Perhaps "CMD+C" minus the quotes & plus?[emoji848]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
      • 30029
      • copier tech
        • 8133
        This video assumes I still have a MAC OS installed on a partition, I don't. The imac has a totally black/formatted SSD.
        The mac will boot off a USB or Windows DVD but not the imac DVD or a mac USB I created.
        • qbert69
          • Mar 2013
          • 1152
          Did you try the key combo I suggested at startup???[emoji848]
          "CMD+C" or perhaps "CMD+D"
          Also:
          Mac startup key combinations - Apple Support
          • copier tech
            • 8133
            Also:
            • qbert69
              • Mar 2013
              • 1152
              Is the SSD that you installed specified to be compatible with that mac??? Additionally when you do the key combinations, you have to hold down all the specified keys at once!!![emoji57]
              • qbert69
                • Mar 2013
                • 1152
                Have you tried the NVRAM/PRAM reset???[emoji848]
