Access less secure Gmail apps
  • Bix
    • Apr 2018
    • 1421
    Hi, Google recently seems to have removed the "Less secure app access" option.
    This is a problem for me especially with old printers (for example bizhub C364e). Scans now no longer work.
    Has anyone else noticed this?
  • buzz
    • Aug 2013
    • 288
    Re: Access less secure Gmail apps
    Following
    This may be a generator for a bunch of calls...
    • clint@clintsimonsen.com
      • 125
      I recommend that you start using a service like SMTP2go I'd also then recommend changing the customer a scanning fee of $ 5 a month.
      Sent from my ONEPLUS A6000 using Tapatalk
      • qbert69
        • Mar 2013
        • 1152
        What's Next?!...Adding Two-Factor Authentication for Copy Machines?!?!?![emoji15][emoji23][emoji1787][emoji38]
        Sent from my SM-N950U1 using Tapatalk
        REACH FOR THE STARS!!!
        Konica Minolta Planetariums!
        • Bix
          • Apr 2018
          • 1421
          I am concerned that the call also comes for recently installed printers. Maybe with the firmware update I could solve but it would also take an alternative plan.
            • 30577
            It's still there on both on my Gmail accounts
            • Bix
              • Apr 2018
              • 1421
              UPDATE! The option appears to be back in stock and customers are now able to crawl again.
              However, it's a nice problem. I don't know if it was for a Google maintenance or a possible test to remove this availability.
              • tsbservice
                Field tech
                • 8082
                Same here.
                • diedux
                  • Jan 2017
                  • 124
                  Control access to less secure apps - G Suite Admin Help
                    • 30577
                    Originally posted by diedux
                    Disabling, but not for all users. In future, this feature will be removed in general.
                    Google state:
                    Google will automatically turn off the Less secure apps setting on individual accounts for users who stop using it. Users can turn it back on until the setting is removed.
                    The Less secure apps setting will be removed from the Admin console in Feb 2021. If you haven’t already transitioned to more secure apps, do so by this date.
                    You can read more here:
                    Seems like it's one of those Updates that looks good on paper until they start getting tons of complaints
                    • Bix
                      • Apr 2018
                      • 1421
                      This will be a big problem
                      I usually always set "Allow less secure apps" to make sure it works. But in the latest printers how will we proceed? It seems to me that even on new printers you have to activate "allow less secure apps". Any ideas on configuration without turning off that option?
                      • diedux
                        • Jan 2017
                        • 124
                        You will have to use App Password for each device (un-secure client) instead of letting less secure apps to connect to Google services by default.
                        Generate App password and use it on your MFD. SMTP authentication wil be yourgmailaccount@gmail.com/gene rated pass word.
                        I've done it for my Outlook but same goes for MFD's.
                        Then add custom App:
                        Use that app password on MFD:
                        Edit:
                        More info here:
                        Sign in using App Passwords - Google Account Help
                        • tsbservice
                          Field tech
                          • 8082
                          [ATTACH=CONFIG]45589[/ATTACH]
                          [ATTACH=CONFIG]45590[/ATTACH][ATTACH=CONFIG]45591[/ATTACH]
                          [ATTACH=CONFIG]45592[/ATTACH]
                          Edit:
                          More info here:
                          Interesting reading. Thanks.
                          • srvctec
                            Former KM Senior Tech
                            • Oct 2009
                            • 827
                            Agreed and I never thought of using this option for MFP's. I had to do this very thing a few weeks ago when my IP camera at home quit sending me motion detect notifications through my Gmail.
                            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                              • 37652
                              The only change I can see in Google's support article for setting up MFPs and other scan to email devices is that SMTP relay service is only available for G Suite editions. If your customer does not have G-Suite they no longer can use the relay service. The other option is to setup a local relay using Stunnel or a similar software.
                              Send email from a printer, scanner, or app - G Suite Admin Help
