Why do Emailed PDF get larger
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1888
    Does anyone know why this happens. It only happens when sent exxternally. A scanned file I sent to a customer & copied myself on was 3.8mb when I rec'd it & almost 9mb when the customer rec'd it. Just curious. Tried to Google but couldn't really find an answer.
    Thanks,
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
  • schooltech
    School District Tech
    • Jun 2008
    • 504
    That's a major increase in file size. I know that some encoding does take place, which can add about 30% to the file size and adds overhead to the file.
    Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
    • CopierTechofOmens
      Agitating Artificer
      • 268
      The destinations may have different default compressions or resolutions. Sharp? In the address book on the webpage you can set the default to PDF G4 for the best compression
      sigpic
      • Baphomet
        Copier Technician
        • Aug 2008
        • 293
        That's because all binary have to be encoded using only a subset of the full 255 byte ASCII set. So a binary file like an Acrobat file has to be encoded into a different format, so it will normally end up 20-30% bigger than the original file. So, instead of the full 255 bytes, only the characters A-Z, a-z, 0-9 and + and / are used.
        See Wikipedia here:
        en.wikipedia.org/wiki/Base64
        (Binary files according to this are actually 137% bigger on average)
        • tmaged
          • Oct 2008
          • 1888
          Thanks for the replies. You guys ROCK !
          Hope that helps !
          -Tony
          www.dtios.com
