Konica minolta c550, network tab not available
  • Hq3r
    • Sep 2020
    • 2
    Hi guys, hope you call are doing well, I mean facing issue with network tab I can't connect with tcp/IP with ethernet cable directed connected with pc and machine, I had luck at USB connection worked but now it is gone too...
    In setting paper, I do get a IP address and Mac but when I try to install printer it never shows up.. I have read some old posts on this forum and tried few stuff and learned, last thing I did was, changing auto IP off and keep on manual IP because I had to install printers everytime after powering off .
    Waiting for your response 😌
  • tsbservice
    Field tech
    • 8053
    Re: Konica minolta c550, network tab not available
    Try to reset network settings.
    • Synaux
      • Mar 2012
      • 1224
      He will need the NVRAM / NIC reset firmware.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4773
        Few stupid things to check,
        HDD is installed
        Is the controller set to "0" in serv mode if no Fiery
        • Synaux
          • Mar 2012
          • 1224
          HDD is installed
          Set it to 1 if Fiery installed.
          You are absolutely correct, I went full FW.
