Need some advice on learning networking
    • 16391
    #376
    Re: Need some advice on learning networking
    I now have a MUCH better understanding of the different roles a server can play in a network environment. When they talk about DNS on a server, they're not talking about resolving host names to an IP address on the internet. No, they're talking a local domain on the network. And on that local domain the server basically takes over many functions from the PC and router. I'm talking about security settings, passwords, level of access, DHCP, ect.
    The administrator can set up group policies for users or computers. There are security features out the ass on Windows Server 2019. Even the way you log in is different.
    I have a long way to go but as they say, Rome wasn't built in a day.
      • 30219
      #377
      You need more help with
      understanding DNS
      • tsbservice
        Field tech
        • 8016
        #378
        ...I have a long way to go but as they say, Rome wasn't built in a day.
        True that. Nobody knows everything. This thread rise unbelievably long yet still entertainment to read..
          • 16391
          #379
          I'm getting a little deeper into Windows Server 2019. I've learned that it still uses Windows Defender Firewall. But it's different in that the Administrator can apply different rules for different PC's.
          For instance: Lets say there's a company called ABC Car Dealer. Inside of that company there are 3 different departments: 1)Administrative 2) Sales Staff 3)Repair Center
          From the server the administrator can allow File & Printer Sharing for the Administrative department and Sales Staff but block it for the Repair Center.
          If you're a copier tech and you go to install 1-copier in each department...you'll be able to set up Scan to Folder with no problem in the Administrative Dept and for Sales Staff, but it's not gonna work in the Repair Center until the IT guy enables File & Printer Sharing.
          It's interesting to get a look under the hood of a server.
          That's all for now.
            • 16391
            #380
            Also, its been mentioned on here that a tech was doing an install and was given an IP address for the copier but couldn't ping it and it stil worked fine.
            The reason for that is the IT Admin had disabled Protocol ICMPv4 for that particular IP address. Ping uses ICMPv4 to ping an IP address.
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              #381
              Also, its been mentioned on here that a tech was doing an install and was given an IP address for the copier but couldn't ping it and it stil worked fine.The reason for that is the IT Admin had disabled Protocol ICMPv4 for that particular IP address. Ping uses ICMPv4 to ping an IP address.
              Trivia question: What port number (if any) does ping.exe use by default? You have 30 seconds... and NO Googling!
                • 16391
                #382
                LOL. I'm not gonna lie to you...I don't know.
                  Good question got me thinking I mean googling, got any more?
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    #384
                    The answer: None. It was a trick question.
                    Billy's post about ICMP got me thinking about it. I've had this issue come up many times before.
                    Rather than me copying and pasting, check out the site below. Yeah, I Googled it. Sue me.
                    How To Ping Specific Port Number – devconnected
                      • 16391
                      #385
                      Good info in that article. It mentioned telnet. I've been using that a lot for troubleshooting SMTP. I've found it very useful. I talked about it in this thread.
                      Edit: I actually used telnet to send an email.
                      Edit 2: I've been meaning to thank Ken for turning me on to VMware. It's the greatest thing since sliced bread. You can build a virtual network with multiple servers. Thank you.
                      • tsbservice
                        Field tech
                        • 8016
                        #386
                        Although I agree on using telnet for troubleshooting scan to email problems, telnet client should be first turned on in Windows features which may be sometimes problematic on users PCs.
                          • 16391
                          #387
                          Everything I'm doing is on my computer lab. I haven't actually used it in a customers office. Yes, I had to enable Telnet on my PC. Thus far I haven't encountered any problems. What type of problems are you referring to? The last thing I want to do is create a problem.
                          • KenB
                            Geek Extraordinaire
                            • Dec 2007
                            • 3944
                            #388
                            You're quite welcome.
                            I actually spend most of my time in a Ubuntu Linux VM, so I can keep my Windows 10 machine as "cootie-free" and clean as possible. I only use Windows when I have to, and normally in a Server 2019 VM.
                            My next step is to get some more RAM so that I can run both VMs at the same time. With only 12 GB, it's a bit sluggish. Santa didn't bring me any for Christmas, so I guess I'll have to buy it on my own.
                              • 16391
                              #389
                              Right now I'm running 2 Windows 2019 VM servers and it's definitely sluggish. I have a friend that has built several PC's for me. I think I'm gonna have him build me a PC powerful enough to run several VM's. It's such a great tool for learning. I've trashed several virtual operating systems by experimenting and it's easy to just delete and start over. I've become a damn expert on VMware. lol
                              • KenB
                                Geek Extraordinaire
                                • Dec 2007
                                • 3944
                                #390
                                I used to support a bunch of different software, including RightFax, Equitrac, AutoStore, Streamline, eCopy, Laserfiche and others, where I needed a demo copy running in the office to test with and use in customer demos.
                                We were able to get a server with a lot of RAM, where we had at least 10 different server VMs running, normally 5 or 6 at a time.
                                A lot of these software solutions didn't play nice together, so they had to be run on separate servers.
                                If a VM ever got funky, it took only minutes to spin up a new one.
