Need some advice on learning networking
    • 16480
    #721
    Re: Need some advice on learning networking
    I need some advice.
    I'm getting to the stage in the CCNA course that the virtual program that I've been using to configure routers and switches doesn't support all the functions of the real thing. So, I'm about to spend whatever money I have to spend to build my own home lab. I already have some of the stuff I need.
    Here's where I need some advice:
    A while back I ordered a server off ebay but it had problems and I got a refund. I'm about to order another server but don't know which one I need. I'm gonna be running a bunch of virtual machines via VMWARE and I'm gonna use it here at my office as a file server, DNS server and will set up active directory.
    I want a rack server. Preferably made by DELL.
    Can anyone offer any advice?
      • 37590
      #722
      I need some advice.
      You might be better off building your own server with all the features you will need. I suggest that it use Linux as the OS. You should then be able to setup a Server 2019 VM and multiple Win10 VM.
      • rthonpm
        • Aug 2007
        • 2859
        #723
        I need some advice.
        Don't get anything older than a x20 series PowerEdge, but you may want to look at a tower server: depending on where you're putting this server, rack boxes have a tendency to be very loud when all of the fans get going. Make sure you've got a RAID card in it, and depending on your drives go RAID 10 for spinning drives or RAID 5 for SSD: RAID 5 and spinning disks area no-go. For spinning disks, get as large as you can afford with a minimum of 4 to support RAID 10 (you'll need Dell branded drives if you're using a Dell branded RAID card).
        Use a Type 1 Hypervisor like ESXI or Hyper-V Server as opposed to installing an operating system and then using VMWare player or VirtualBox or some other type 2 hypervisor, otherwise you've wasted money investing in a server. I'm personally a Hyper-V guy, but either ESXI or Hyper-V will work well as a platform.
        There are more reliable sites than eBay as well, though you will definitely end up paying more, you at least get a warranty and support. XByte is a good source for servers, but you'll pay a lot more than eBay.
        If you're doing AD, your domain controller will also act as your DNS server, but you can install DNS as a separate service on its own server. My personal lab consists of a domain controller, Windows SMB (file) server, IIS (web) server, all of them are Server Core installs, a Linux (CentOS 7) Apache server (bound to Active Directory), and a couple of Linux and Windows workstations, all bound to Active Directory. I tend to wipe the machines and start over quite frequently, as I mainly use it as a demo for customer setups. For Windows systems, you can download evaluation copies of all Windows Server versions which are good for 180 days, and re-loadable for an additional 180 days up to three additional times.
          • 16480
          #724
          I went to the xbyte site and did my best to spec out a server but unfortunately I got lost in he plethora of specs.
          I hate to ask you to do this but I don't want to make any mistakes. Would you mind going to their site and choosing the options that I need? And maybe taking a screen shot and sending it to me? I have a budget of about $1500.00.
          If it's too much trouble, I completely understand. I hate to ask you to do this.
            • 16480
            #725
            I've been reading up on the difference between Type 1 & 2 Hypervisor and this is really cool stuff. From my understanding, the main benefit of Type 1 over 2 is reliability and redundancy. In other words, if one instance of an operating system dies on a physical server, it can migrate to another server in real time. Crazy stuff. I'm still a little fuzzy on some details.
            • rthonpm
              • Aug 2007
              • 2859
              #726
              You can set up replication or clustering with a Type 1 hypervisor, yes, but the bigger advantage is that your VM's are running closer to the bare metal of the machine. A type 1 hypervisor gives your VM's closer access to the physical hardware of the device since there's no other operating system between the VM and the hardware. A Type 2 hypervisor still needs an operating system to run in since it's a piece of software (think VirtualBox), so you're adding in an additional step and weight since now you need more resources just to run the OS that runs your hypervisor, or some just offer a generic set of hardware that doesn't take advantage of the memory or other features found in your hardware. You'll find servers using a type 1 because you want performance as close to native as possible. There's also the licensing aspect: you can generally run a Type 1 hypervisor with free software: Microsoft offers Hyper-V Server, which is just the hypervisor related portions of Windows for free, ESXI from VMWare is also free. Go with a Type 2 hypervisor, and you'll need to run an operating system and then your VM's on top.
              Fun fact: enabling the Hyper-V role in Windows 10 actually turns your computer into a Type 1 hypervisor as your OS becomes a VM running on Hyper-V.
                • 16480
                #727
                I see. They mentioned something about that in a video that I watched. I didn't quite understand but now that you explain it, I get it.
                I got your PM. You've been so helpful. I really appreciate it. I'll try not to bug you too much but I'm sure I'll have more questions. Thanks again.
                  • 16480
                  #728
                  I learned how to do something really cool today.
                  Remember that I said on a production network that PC's aren't usually plugged directly into a layer 3 switch but are instead plugged into a layer 2 switch that is trunked to a layer 3 switch? The reason that it's trunked is to allow vlans across those inter-connected ports. And those vlans have to be configured on every last switch. That could be 10 or 20 switches. Or more. Depends on the size of the company. That takes a long time and it's very easy to make a mistake when configuring the switches.
                  There's an easier way. You can turn that layer 3 switch into a vlan domain server and the layer 2 switches into vlan domain clients. What does this do? Instead of me having to configure all those switches, the layer 3 switch does it for me. Cool stuff.
                    • 16480
                    #729
                    I've come up with a new game plan for passing my CCNA on the first attempt.
                    After looking at what's involved in this course, I have broken it down into 2 key areas:
                    1. Practical learning. This consists of actual programming of the switches and routers and making them get the information to the right part of the network.
                    2.. Theory based learning. This consists of things like the OSI model, subnetting, broadcast and collision domains, ect.
                    Number 2 not only involves learning a lot of theory, but it requires a LOT of memorization. It is for this reason that I enrolled in a 2nd online course that deals in the theoretical side of networking. The course I'm taking now is heavy on practical learning, and doesn't go deep into theory...not enough to pass the test, IMHO.
                    I figure it's gonna take about 10-12 months before I'm ready to take the test.
                    PS - For anyone thinking of getting their CCNA, I say do it but know what you're getting into.
                    • kuby
                      • Oct 2007
                      • 1413
                      #730
                      Yea it is not a piece of cake. Seven of us went to take the test and only three of us passed it. But that was back in 2004.
                        • 16480
                        #731
                        So, I'm going thru the 2nd course from a different instructor. I started to skip over the basics because I felt I already had it down pat. But I decided to go through it again. Now, I'll admit it was very boring going back over things that you already know. However, the first time around my head was spinning even when covering the basics. That "basics" aren't so simple when you don't know 'em.
                        Anyway, this time my head wasn't spinning and I was able to pick up some things that I didn't the first time around. Specifically, I was able to key in on public IP addresses and give it my undivided attention. The CCNA test is gonna cover all the basics and you gotta know 'em inside and out.
                        By the way, IP addressing and subnetting are a huge part of networking. That's where it all starts.
                          • 16480
                          #732
                          Congrats on a job well done. Unfortunately for me they've added a lot to the CCNA test since 2004:
                          Under the old CCNA certification program, there were multiple concentration exams for different learning paths. However, under the new rules, the following certifications have all been replaced by the new CCNA:
                          CCNA Cloud
                          CCNA Collaboration
                          CCNA Data Center
                          CCNA Industrial
                          CCNA Routing and Switching
                          CCNA Security
                          CCNA Service Provider
                          CCNA Wireless
                          CCDA (Cisco Certified Design Associate)
                            • 16480
                            #733
                            I'd like to share a conversation I watched on YouTube between the instructor in the course I'm taking and a software developer. Before I share the conversation, let me ask a question:
                            is a Network Engineer today's plumber? (if you don't think so, you may change your mind after hearing the conversation)
                            Software Developer: "Most of the networking done today is logical. Logical is just another name for software. A network engineer is the equivalent to a plumber in the 1970's."
                            My instructor: "I don't feel like a plumber. I spent of lot of time on my certifications and I work in a high tech field."
                            Software Developer: "From my perspective, we write all the software that give routers and switches the ability to move data over a network...all you do is connect the pipes."
                            That was the gist of the conversation. It made me think about a lab that I completed the other day where I configured a Layer 3 switch to be a VLAN domain server. I was amazed that a Layer 3 switch could do something so awesome. But the truth is, all I did was turn the feature on by typing in a few command lines. It was the software developer that did all the hard work.
                            I'll ask again: Is a network engineer todays plumber? Let me know what you think?
                            • rthonpm
                              • Aug 2007
                              • 2859
                              #734
                              Early in the thread I said that everything in networking has some kind of analogue in the read world. All the majority of it comes down to is packet switching so you're not as much a plumber as an old style telephone operator. You're just plugging packets from point A to point B with as little disruption as possible.
                                • 30483
                                #735
                                Pretty Ridiculous question
                                NO
                                Maybe you call the plumber the next time your network down in Mississippi
