Need some advice on learning networking
    • 16491
    #1231
    Re: Need some advice on learning networking
    Question: I know that every organization is different, but generally speaking, how much do you try to limit domain users?
    No USB drive?
    No Control Panel?
    Any info. would be helpful.
    • rthonpm
      • Aug 2007
      • 2859
      #1232
      No USB drive?
      No Control Panel?
      Just make sure they don't have admin rights for the most part. Control Panel still offers features that a standard user can make and if you block USB ports then you're also killing peripherals beyond flash drives. Flash drives are as much a human resources issue as an IT issue, that's where user training and management buy-in comes into play so that people know there's a penalty for doing what they shouldn't.
      The principle of least privilege is generally used: any role in an organisation should have the least amount of permissions necessary to do their tasks.
      Sent from my BlackBerry using Tapatalk
        • 16491
        #1233
        I'm still exploring Group Policy. I just did something freakin' cool. I deployed Google Chrome to PC's on the domain using Group Policy.
        I know this is old hat for rthon but for me it's like discovering fire.
        • rthonpm
          • Aug 2007
          • 2859
          #1234
          This is how I set up most systems: on binding to the domain all of the default software is installed, or at least everything with an MSI file. Everything else just gets installed through PDQ Deploy.
            • 16491
            #1235
            Correct me if I'm wrong, but only MSI files can be deployed. Anything ending with exe needs to be converted to a MSI file?
            • rthonpm
              • Aug 2007
              • 2859
              #1236
              It's considerably easier with MSI files than an exe, especially as they better support silent installs, which is what you want.
              There are workarounds for exe's, but they usually don't seem to work, and most applications offer an MSI either by default or as an alternative download.
              For your Chrome instances in a domain, be sure to use the Enterprise version instead of the standard download as it offers several improvements for a managed environment.
                • 16491
                #1237
                #1.
                #2.
                #3.
                #4.
                #5.
                You can control all the settings related to your computer mouse here. This includes mouse speed, buttons, wheel, and pointer, etc.
                #6.
                #7.
                #8.
                guide to optimize the power options as you find best.
                #9.
                #10.
                #11.
                d.
                #12.
                #13.
                #14.
                #15.
                #16.
                #17.
                #18.
                #19.
                #20.
                #21.
                #22.
                #23.
                #24.
                #25.
                • rthonpm
                  • Aug 2007
                  • 2859
                  #1238
                  Learn your Windows key shortcuts as well.
                  Win+R run command
                  Win+L lock workstation
                  Win+M minimise window
                  Win+D minimise all windows and go to the desktop
                  Win+Shift+S Screen snip
                  Win+1 through 9 open the application pinned to the taskbar in the order they are pinned.
                  There are others as well, but these are the main ones I use.
                  Another bonus: Ctrl+Shift+Esc Task Manager
                  I'll also raise you dism and wmic as commands that will dig you deep into Windows.
                    Win + printscreen takes consecutive screenshots.
                      • 16491
                      #1240
                      When I first read this, I thought to myself that this is pretty dang cool. My next thought was...how is he doing this?
                      This morning I got to thinking about it. Turns out that it's really not that complicated at all. The link to the GPO is constant. Once I drop a PC into a container, the policy is automatically applied.
                      I created a new machine this morning in Virtual Box and dropped it into a container and, bam, Google Chrome was automatically installed.
                      As always, correct me If I'm wrong or am missing something.
                      • rthonpm
                        • Aug 2007
                        • 2859
                        #1241
                        Only if you want the entire screen, which becomes even uglier with multiple monitors. The times where I want the entire screen as opposed to a specific portion of it is very small.
                        • rthonpm
                          • Aug 2007
                          • 2859
                          #1242
                          The policies aren't immediately applied at the client level unless you forcefully trigger them or wait for the regular policy refresh cycle (every 90 minutes).
                          The easiest ways to apply a policy without going to command prompt is:
                          For computer based policies: reboot, though depending on how deep the new policy is it can take at least two reboots to properly apply. You'll mainly see this with policies that require a reboot to enable a feature within the policy object.
                          For user policies: log off and log back on.
                          There's also the old standby of gpupdate /force as well.
                          • tsbservice
                            Field tech
                            • 8053
                            #1243
                            Win + I Settings
                            Win + S Search
                            Win + , Temporarily shows desktop
                            Win + E File Explorer
                            Win + Spacebar Change keyboard layout and input language
                              • 16491
                              #1244
                              I forgot to mention that I had to do "gpupdate /force". I guess it's not automatic but close enough.
                                • 16491
                                #1245
                                I googled PDQ Deploy. It looks pretty amazing. It's also very expensive. I'm trying out the 10-day evaluation period.
                                What can you share with be about this?
