FTP Scanning Question
  • savedR
    • Nov 2015
    • 8
    #16
    Re: FTP Scanning Question
    Silly question, how come y'all don't use the FTP server with IIS built into Windows?
      • 30257
      #17
      You can on a Windows server however setting it up on a PC usually required the install cd for the added files.
      Filezilla is free and very easy to configure.
        • 37514
        #18
        I should also note that on a Kyocera machine that you need to leave the "path" box blank. When I would enter the folder name, it would not work.
        [ATTACH=CONFIG]47330[/ATTACH][ATTACH=CONFIG]47331[/ATTACH]
        One of the mistakes many people make is to specify the path starting from the root directory of the drive and not the root directory setup in the FTP server. That is why using just . to place the scanned file in the ftp folder.
