printer preferences = thick paper, but old office doc's give error
  • Mark Bbb
    • Jun 2012
    • 1662
    Old office documents would give a "paper thickness error" on a Ricoh (mpc3003) printer if the printer preferences on PC (server) would be set to "thick" (or middle thick...). The printer receive the document but the error light flashes.
    It would print fine (without this error) with all new made Office documents.
    This still happens even after a week the new printer preferences settings (thick) were done.
    We had some problems with upgrading the firmware on this machine, but that seems to be alright now...
    Is it true that printer preferences are saved together with an Office document?
    Is there a way to print these old Office documents without any errors?
    Thanks in advance for your answer.
  • copier tech
    • 8142
    Re: printer preferences = thick paper, but old office doc's give error
    Update to the latest firmware.
    Then you have a couple of options. In printer features change setting to driver command from machine settings. It will then ignore the paper type mismatch.
    • Mark Bbb
      • Jun 2012
      • 1662
      C.T. : Thanks, but where do i find those printer features, it is not in the properties of Exel 2016 on my Windows 10 pc...?
      PS: Customer is using Office365...
      • copier tech
        • 8142
        Its a setting on the machine. Use driver setting.
        Or what about using the auto continue setting?
        • mojorolla
          The Wolf
          • 2606
          You can create Office documents with custom properties. For example, I use a Word document, that will only print from tray 4, when I conduct training classes. Nothing gives me more pleasure than watching newbie fall all over themselves the first time they encounter this (yes, I am a very sick man). Another simple mistake folks make is hitting OK when changing settings. OK will hold it for that job; Apply will hold it forever.
          • Mark Bbb
            • Jun 2012
            • 1662
            C.T., Thank you, but where exactly is this "driver setting" located in the machine?
            System settings?
            • copier tech
              • 8142
              System settings?
              This is the setting I was referring to.
              Applying the Settings Specified in the Printer Driver or Commands When Printing
              • Mark Bbb
                • Jun 2012
                • 1662
                Thanks C.T., the translation to Dutch on these terms aren't always clear...
                • copier tech
                  • 8142
                  That is the setting I use. But the correct way is as mojorolla said but some customers find that too much hassle all they want is to click 1 button, print.
                    • 37480
                    If the problem only happens with old Word documents and not with newly created documents I would say that when the document was first saved, Word was set to "Save printer settings with document." Look for Options, Preferences or Settings within the document under File - Print.
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      I have searched in the options (advanced) of Excell but i can't find anything close to "fit to pressent printer-settings".
                      Nor i can see something related to this problem in printer propertys or printer settings, on machine.
                      • mojorolla
                        The Wolf
                        • 2606
                        You said a dirty word...."Excel". These are great for viewing as a spreadsheet but are a total pain in the ass when it comes to printing. With Excel, I generally use 2007 compatibility mode (or called something similar). There are also issue with printing the tabs, color versus mono pertaining the separate sheets. Try printing an Excel to a bypass tray on a Toshiba and it goes ape shit.. As to the settings in Excel, select print, then at the bottom you will see Page Setup. You can set paper size, dpi, and fit to page. Printing runs on a hierarchy...program, print driver, then machine settings. If the program says Letter, plain, the print driver will try to match.
                        • srvctec
                          Former KM Senior Tech
                          • Oct 2009
                          • 827
                          I had no idea this could even be done. Just tried it and that's pretty cool!
                          Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                          • KenB
                            Geek Extraordinaire
                            • Dec 2007
                            • 3944
                              • 37480
                              It is not that bad, once you learn all the settings you have to make in order to tell it what you want to print and how you want it printed.
                              Select overall print area
                              Hide unwanted rows and columns within the print area
                              Print column letters and row numbers - YES/NO
                              Print grid lines - YES/NO
                              Adjust margins
                              Zoom in/out to get it to at least fit width
                              Header row(s) if it will be more than one page
                              Et cetera, et cetera and so forth
