SNMP monitor
  • copiray
    • Feb 2019
    • 29
    SNMP monitor
    Hello, I am trying to configure the machines that we have in maintenance to be able to connect them through snmp and thus be able to check the status of toner, counters and error codes.
    Do you know of any snmp monitor that works outside the local network?
  • clint@clintsimonsen.com
    • 120
    Re: SNMP monitor
    Have a look at FM audit
    MPS Software – PrintSolv
    You may need to run it on a machine at each client's. Issue with snmp is you have to open ports on router and this is not recommended as it opens security holes for your customers, last thing you want is to be blamed for opening security issues. Also have a look at Arvik sold product used more for full network management rather than just copiers. Easy to to set up email notifications from the device and to you eg toner@bussines meter business etc then set up automation on email addresses.
    Sent from my Nokia 8.3 5G using Tapatalk
    • tsbservice
      Field tech
      • 7963
      Re: SNMP monitor
      Yes there are plenty. Are you looking for a free or paid tool? Free tools I tried inevitably have dead ends.
      PrintFleet is paid tool we're using.
        Re: SNMP monitor
        Printfleet is what we used ... worked fine except when the IT idiots changed settings around .
          • 29785
          Re: SNMP monitor
          Print tracker
          • tsbservice
            Field tech
            • 7963
            Re: SNMP monitor
            Confirm, once installed it would be smooth as silk. Both for the customer and us. As soon as the agent(DCA) runs on their server(ideally) but most of times on local PC (bad idea).
              Re: SNMP monitor
              we had Leith Honda that the IT IDIOTS refused to put it on the server.. so it was installed LOCAL on 23 different PC's ... talk about a fucbar!
