Papercut split scan every n pages
  • fishleg
    • Mar 2009
    • 426
    We have a customer with papercut who needs the scans to be split every two pages as they scan in 100's of 2 page docs at the same time. In the admin interface it has batch splitting but that's applied at the processing level and not at the MFD level so you can split every single scanned doc into 2 pages or not at all.
    Any way to do this?
    I thought of enabling the MFD scanning options and then configuring the scan to go around papercut and straight to the user which would work I guess but it looks like papercut disables it. When I select use local function I just get the copy option and theres no scan function other than to use papercut. Any ideas how you turn on MFD scan function in papercut?
    Thanks for any help.
    • 8192
    Re: Papercut split scan every n pages
    Originally posted by fishleg
    Any way to do this?
    You can set papercut to use native scanning then you can use the batch scanning setting etc.
    โ€‹
    • fishleg
      • Mar 2009
      • 426
      Sorry thick question how would you find that? Total paper cut novice. I know to get into the admin console that's about it..
      You can have both enabled? So both paper cut and native scanning on? Could you enable it for one person?
        • 8192
        Top of my head I can't remember if I was sitting at console I could find it.
        You can set both follow me or native scanning.
        โ€‹
        • diedux
          • Jan 2017
          • 124
          Any way to do this?
          I don't know if I understood you correctly, but you can split every 2 (or whatever number) pages. In other words, you scan a batch of originals and at the output, you get 1 document, then PaperCut splits this 1 document into separate documents according to settings.
          Also, you can use device native scanning. This is a separate thing and it depends on the platform (MFD brand) you use. Native scanning is not restricted by default after installing PaperCut on the device (on some brands - yes).
          • fishleg
            • Mar 2009
            • 426
            Originally posted by diedux
            [ATTACH=CONFIG]49133[/ATTACH]
            Yeah that's right but it's only for one job if you activated that then every single scan job would get split up.
            • diedux
              • Jan 2017
              • 124
              You can have as many "Scan actions" (aka scan workflows) as you like. Every single one of them can have a different configuration. These "Scan action" settings do not apply to all scanned docs, only for that specific one.
