Slnx v3 ,scan to folder issue,
  • fbkhan3
    • May 2012
    • 421
    Hi everyone,
    Hope you doing very well.
    We recently installed slnx v3 for one of our client, it takes too long to get the files in scan folder. To get the files in pdf format workflow is as ""pdf converter- scan to folder ". 6mb file would take almost 6 minutes and as the size of the file increases it adds more delay.
    It is also tested from different devices and models , MP 6055,5055, IMC 3000, MP 6503 with same results.
    Native scanning works very well to the same location without any delay.
    Need ideas.
    Regards
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Re: Slnx v3 ,scan to folder issue,
    Which version of SLNX 3 are you running?
    There have been several updates for it.
    • fbkhan3
      • May 2012
      • 421
      It's 3.3.2.200
      Has this been the case with few versions of the software?
      Regards
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Not that I'm aware of.
        I don't see a patch for that version (other than upgrading to 3.4.1)
        Is all the firmware including the SOP panel and java (where applicable) up to the required versions?
        Do you get the same result if using SLNX to scan to email?
        Make sure the DS has the network side configured properly. There could be a DNS issue which will make you crazy until found.
        Lots of other possibilities, too, such as is there a NAS or other storage media involved? NASes can open up an entirely different can-o-worms.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Just thought of this...What version of the client is running on the MFPs?
          A mismatch will cause all kinds of issues.
          • fbkhan3
            • May 2012
            • 421
            All the firmwares on the devices are updated to latest including SOP & Java,
            We didn't check this large files as Scan to email, size in kB works without any delays.
            NAS and user home directory both checked to rule out the NAS issues, native scan also works perfectly to both locations.
            firewalls are off .
            completely lost.
            Regards
            • fbkhan3
              • May 2012
              • 421
              I will check the version of embedded app and repost.
              Regards
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                firewalls are off .
                completely lost.
                Regards
                I once had a customer with SLNX 2.3 (I think) who had the same slowness issue, and they were using a NAS. Onboard scanning was cool.
                Turned out to be that the NAS had some problems with SMB1 versus SMB2/3, and the SLNX server had a problem with it.
                An update to the NAS resolved the problem.
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  Just for laughs, set up a hot folder using the same workflow as the one with the issue.
                  The flow will be the same, except that the MFPs and their connections will be bypassed. The flow would come straight from the DS.
                  if it's fast, the problem lies with the MFPs or their software. If it's the same, the problem lies between the DS server and the storage destination.
                  • fbkhan3
                    • May 2012
                    • 421
                    Actually when converting to PDF it all gets messy, if we select the profile (workflow) on machine it makes it bit faster but the size of the file goes large, and if we keep the profile on server then size of the file reduces but it makes it so slow. clueless at the moment.
                    Regard's
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      Regard's
                      Could you send me some screenshots of the profile?
                      PM me if you prefer.
                      • fbkhan3
                        • May 2012
                        • 421
                        Sure, I will try to get to remote tomorrow and get the screenshots and PM you, but here is the finding that we had today.
                        1:Native device scan( B&W; Text and line, 300dpi ) file size 14mb /time 3 mints
                        2:NO pdf converter ( B&W; Text and line, 300dpi ) file size 15.2 mb /time 1.12 mints (fault causes TIFF)
                        3: With pdf convertor ( B&W; Text and line, 300dpi ) file size 16 mb /time 3 mints profile processing on device
                        4: With pdf convertor ( B&W; Text and line, 300dpi ) file size 6.5 mb /time 8 mints profile processing on server.
                        Time duration with different profiles and size of the file 72 pages in all cases. file processed on the server has the correct size but time it takes is too long.
                        Regard's
                        • fbkhan3
                          • May 2012
                          • 421
                          hi folks,
                          This issue has been solved, Ricoh Recommend to do Profile tuning which is actually to increase the threads for scanning, it didn't solved the issue at first but somehow restarting the main server did the trick and scanning works perfectly fine now.
                          The tuning process is also available in Documentation.
                          Thanks for all your valuable inputs.
                          Regard's
                            • 37240
                            hi folks,
                            Regard's
                            Every time I have ever modified a server profile to increase the number of simultaneous threads it required a reboot in order for the changes to take effect.
                            • fbkhan3
                              • May 2012
                              • 421
                              SLNX is running on VM which we restarted after every adjustment and change, but i guess changes took effect after restarting the Main.(that was only possible on weekends). as this was production environment.
                              Regard's
