Wireless bridge
  • knobby
    • Oct 2008
    • 75
    Wireless bridge
    Hi,
    has any one used a wireless bridge to connect a Ricoh MFD to a wireless network ... and if so did you loose any functionality ?
    I'm sure it will work but need to know its limitations if any
    cheers in advance
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1887
    I've done them on Sharp & Toshibas without any problems. You shouldn't loose any functionality as it's the same as a wired connection in the MFP's eyes.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • TheOwl
      • Nov 2008
      • 1732
      You could do this for just about any network device. All you would need is a wireless router connected to the copier.
      In doing this though, I would set the router to AD-HOC mode and get it to connect to your existing wireless gear just to increase security surrounding the wireless connection.
      On the other hand, you could use the router as a general access point for everyone and just connect the copier via RJ45.
      Alot of ways to do this, but at the end of the day, all you will be doing is access the copiers IP address through Wi-Fi.
      • GCOP_Tek
        Platinum Member
        • 22
        Lately I've been using the Linksys WET54g and have full use of all functions on the MFP. I just connected a Savin 4035Esp with one today.
        • pepper38_cnd
          Field Service Manager
          • Aug 2005
          • 1075
          No loss in funtions, try using a wireless gaming adapter! works great and low cost, easy to configure, Linksys, Dlink, or any that you can find. I've used many, with n o problems.
          Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
          Now into Ip TV KODI Boxes
