Ports tab in Printer properties is empty
  • printajsifajl
    • Jul 2024
    • 40
    I hope this is a right forum for this question.
    Customer has one laptop that, when I tried to change Port setting, and they have empty ports list. When I tried to add new printer/new port. I get Filename is is incorrect.
    Any ideas.
  • Heisenburg
    • Oct 2024
    • 6
    How was the printer originally installed? Are you connecting by IP address, node or is this a shared printer that's physically connected to another machine?
    • printajsifajl
      • Jul 2024
      • 40
      This "empty port list" happens even if I open Microsoft's Print to PDF printer.
      • Heisenburg
        • Oct 2024
        • 6
        I was trying to get an idea of how the printer was configured since I see "DC" in the name of the properties, as if the printer is being physically shared from a Domain Controller. Create a test user account with Admin privileges on the laptop to see if the issue is user acct related.
          • 37529
          He has something redacted in front of the DC01 that makes me think that the redacted text + the DC01 is actually the name of the print server where the MP 501 driver actually resides. Odds are that the computer is part of a Domain and the logged in user does not have Domain admin rights.
          • mojorolla
            The Wolf
            • 2627
            Agreed, the changes to the port will need to be made at the server level.
            That would also explain why there are no ports....
            • Heisenburg
              • Oct 2024
              • 6
              Yes, exactly. If it's a workgroup PC, a test user account can rule out a user registry error.
              • printajsifajl
                • Jul 2024
                • 40
                Sorry for misinformation. Pictures are not from my customer. Just a sample I got from internet so I can better convey my question. Here is customer's computer picture. We'll try to create new user to see if it's User not Windows problem. Thanks for the suggestion.
                  • 37529
                  Still the question remains, does the logged in user have administrator rights?
                  • printajsifajl
                    • Jul 2024
                    • 40
                    Yes. they have admin rights.
                    • Blizzoo
                      • Aug 2013
                      • 608
                      Even though without admin rights there should be a list ports/IP's etc, not just blank. Does the Print Management feature is installed? Can you see anything in Ports? Does the Print Spooler service running?
                        • 37529
                        The Spooler can be restarted from Task Manager. At the left select Services, scroll down to Spooler, right click on Spooler and select Restart.
