SC899 on Ricohs
  • TonerMunkeh
    Professional Moron
    • 3865
    SC899 on Ricohs
    Evening all,
    Just a quick heads-up on this one, been getting this more often recently. Microsoft Edge is the default application to open PDF's in clean installs of Windoze and causes SC899 when certain fonts are printed. Installing Acrobat / Foxit or printing the PDF as an image is a cure.
    Hit it.
    • 37345
    Re: SC899 on Ricohs
    Originally posted by TonerMunkeh
    Evening all,
    Also stop using the POC that is Microsoft Edge and install Firefox.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Re: SC899 on Ricohs
      Micro$oft hates printing, and anything associated with it.
      They prove it time and time again.
      • tsbservice
        Field tech
        • 7975
        Re: SC899 on Ricohs
        I never thought using Edge as web browser what comes for PDFs viewer Just drop that shit and use Foxit or Acrobat readers as mentioned.
          • 37345
          Re: SC899 on Ricohs
          If you install Revo Uninstaller you can remove Edge from your system.
            • 37345
            Re: SC899 on Ricohs
            The last version of Acrobat reader that I liked was v9.1. I had to get a new laptop a few months ago when my old one refused to boot. When I tried to download 9.1 from Adobe I found out that they no longer offered it so I found Foxit. Not quite the same but still acceptable. Reading this thread I decided to make another check for Reader 9.1 and found it at Oldversions.com.
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              Re: SC899 on Ricohs
                • 37345
                Re: SC899 on Ricohs
                But it gets rid of annoying popups from Windows wanting you to try Edge.
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  Re: SC899 on Ricohs
                  So true!
                  • anothertech
                    • 1760
                    Re: SC899 on Ricohs
                    Keeping ALL firmware up to date all of the time seems to take care of the SC899's.
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      Re: SC899 on Ricohs
                      As crazy as it may sound, this includes Java, if so equipped.
                      I got burned by that a few times.
                      • rthonpm
                        • Aug 2007
                        • 2848
                        Re: SC899 on Ricohs
                        Giving tips to remove Edge, which breaks the HTML rendering engine for Windows AND using an end of life version of Acrobat with known vulnerabilities?
                        Not a good look...
                        Sent from my BlackBerry using Tapatalk
                          • 37345
                          Re: SC899 on Ricohs
                          Not a good look...
                          Maybe for some but Edge from its inception has caused me nothing but headaches. As for Acrobat 9.1, I have never had problems with it. I have with 10.0 and later versions.
                          • rthonpm
                            • Aug 2007
                            • 2848
                            Re: SC899 on Ricohs
                            Newer versions of Edge are really nothing but Chrome since Microsoft stopped trying to build its own browser engine and just adopted Chrome.
                            The original flavour of Edge was pretty rough. I'm mainly a Firefox ESR user, but for those pages that it doesn't render well Edge is my secondary browser.
                            Acrobat is one application that needs to be kept up to date as it is so widely used that it has a big enough target on its back for any vulnerabilities. I pay for the full version since I need to be able to create forms and edit existing documents. The subscription also gives the ability to edit PDF's on mobile devices.
                            • KenB
                              Geek Extraordinaire
                              • Dec 2007
                              • 3944
