BH-C-284e, SMB scanning, how to set up for a MAC
  • Hansoon
    • Sep 2007
    • 3385
    Anyone having for me a set-up guide how to configure a BH-C-284e, for SMB scanning to a MAC please?
    Hans
  • Copier Tech Specialist
    • Jan 2025
    • 19
    you can try this option to configure SMB using using BOX
    Configure scan to SMB using BOX https://youtu.be/QtiK_T3k-iM?si=I1WYOyEh-lswc89F
    In MAC click on Go>Connect to server
    Enter the IP address of the printer under Server Address
    If prompt for user name and password
    Username: guest
    Password: blank
    • Hart
      • Feb 2024
      • 403
      • Hansoon
        • Sep 2007
        • 3385
        With networking in a MAC environment, I'm a total noob, so please be patient with me 😁.
        Question: If the file sharing has been set up properly on the MAC and my Windows computer is in their network, can I then test it with my Windows computer with the following path:
        \\MAC\SMB (where MAC is the computer name and SMB the shared file) ?
        Hans
        • Hart
          • Feb 2024
          • 403
          To let users connect to your Mac from a Windows computer, turn on file sharing and enable SMB sharing.
          • Hansoon
            • Sep 2007
            • 3385
            Yes, that's clear in between.
            But....., how can I check with my Windows computer if the MAC has its file sharing and SMB turned on, if it doesn't work?
            With Windows computers, I can test the file sharing by doing
            \\Hans\SMB
            (where Hans is the computer name and SMB the shared file)
            I presume that it's the same with MAC, but like to be sure.
            Hans
              • 37489
              You should be able to use "Map network drive" or Network discovery.
              • Massimiliano
                • Oct 2019
                • 47
                Username: guest
                Password: blank
                Hi,
                I don't have the option highlighted in the client's c224e.
                Do you know how to solve it?
                Thanks​
                This gallery has 1 photos.
