Microsoft Surface tablet printing using an ARM based SnapDragon processor
    • 8208
    Does anyone have any experience printing from a Surface tablet to a copier?
    I understand most copier OEM's do not provide a print driver for this and that you must use a generic Microsoft IPP print driver supplied by Microsoft.
    Advanced features like Dept Codes, Private print are not avilable with IPP drivers.
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 709
    Sharp, Kyocera, and (soon) Epson will have ARM drivers. What manufacturer of printer are you looking for?
      • 37520
      Most manufacturers are currently working on releasing ARM compatible drivers. And it is not just the Surface tablets, some laptops are also effected.
      The delay lies with Microsoft.They are trying to hold the entire industry hostage through licensing.Similar to what Adobe did with PostScript.
        • 8208
        Toshiba hhas no plans to develop an ARM compatible print driver. The market is too small.
        The customer should be considering the Surface Pro featuring an Intel processor. A regular PCL print driver pointed at an IP address can be used.
        The ARM processor is limited because it is designed for mobility over productivity.
        • Hart
          • Feb 2024
          • 411
          huh ?
          Unlock next-gen AI with Scaleway's COP-ARM: seamlessly blending eco-efficiency, cost-effectiveness, and AI-optimized performance for tomorrow's cloud solutions.
          • rthonpm
            • Aug 2007
            • 2859
            Mopria is the preferred solution for most modern devices. If the device doesn't support it you may have a new sale on your hands .
              • 8208
              OK, I will get the customer to specify Mopira certified in their spec check. I can handle it well. Thanks,
