can i create a ricoh scanning using cmd?
  • aviso66
    • Dec 2012
    • 202
    can i create a ricoh scanning smb folder just using cmd batch?
  • Gift
    • Mar 2011
    • 2458
    Re: can i create a ricoh scanning using cmd?
    I'm not shure but you can try this tool:
    Scan to Folder Configuration Tool Downloads | Ricoh Global
      • 37235
      Possible but you would need to be really good at writing batch file scripts. You would have to use either TWAIN, WIA (USB) or NetWIA driver and a software that uses one of them and can be launched from the command line with all the needed parameters required for the scan passed from the command line through the software to the driver. IMHO it would be a total waste of time.
      • rthonpm
        • Aug 2007
        • 2847
        You can easily create a shared folder via command line. The real issue comes in properly setting the permissions as open shares are never a good idea.
        Sent from my BlackBerry using Tapatalk
        • copier tech
          • 8130
          Why would you want to set this up the hard way?
