IPP, bonjour, chromebook, Meraki, ubiquiti
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    Got a couple of cases of Canon's time out with either Mac or chromebook environment. It would
    Show itself as offline.
    I used "time out" to describe the symptom, that's what it look like. As to what it really is, I have no clue.
    What is found is when IPP is toggle off and on, the printer shows it self as online again.
    The question is, anyone know what causing the timeout?
    Only happens with Advanced router environment.
    *interestingly enough, chromebook will display the host name set for airprint... This is new to me
    Idling colour developers are not healthy developers.
  • tonerhead
    • Sep 2009
    • 582
    Re: IPP, bonjour, chromebook, Meraki, ubiquiti
    Why are you using IPP?
    I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
    Especially when it comes to sex
    • J_Arnold
      IT Director
      • Sep 2021
      • 87
      Chromebooks require IPP, they are still working on a solutions since they were never supposed to be used in the environments they now find themselves in. I find they will print but don't recognize features..ie..Finishing options, stapling etc. Airprint is IPP as well.
      “First comes smiles, then lies. Last is gunfire."
      • J_Arnold
        IT Director
        • Sep 2021
        • 87
        *interestingly enough, chromebook will display the host name set for Airprint.... This is new to me
        Chromebook is playing with CUPS like features to figure out their printing toboggle. You are trying to do cloud based printing in an advanced routing setup, that is going to consistently give you a headache. MacBook might be related to SSL certifications and timeout after new update. Airprint is now Secure Airprint Waah ahh ahh!! Use LPD for the MAc and point it to the IP address of the MFP. Good luck with the Chromebook.
        • tonerhead
          • Sep 2009
          • 582
          That is interesting. I have a chromebook, I have set up chromebooks, I have never used IPP. Same with Macs, never. It seems like appsocket, jetdirect or tcp/ip works without failure for me. I guess I am assuming though that the chromebooks and macpads link to lan for internet, not through like apipa reaching out for whatever is available off network. I have taken Macs away from airprint and recreated printers through appsocket or equivalent. Seems to work much better. Just saying maybe I'm doing it wrong, but in my mind works better than IPP.
          Most manufacturers create specific drivers for macs, so I don't use cups unless needed. The trouble with Chromebooks are manufacturer's don't write many drivers for them, just generic that print and maybe duplex.
          I have found with phones, manufacturers have their printing and scanning apps which allow printing scanning capabilities. I might guess these use IPP connection to apipa networking. Don't know for sure.
          I'm not an expert on this stuff. Just saying what has worked for me and asking a question about IPP. I remember years ago IPP seemed to be used primarily in long distance printing like an office in NY printing through the internet to an office in CA. Now businesses have vpn's etc and 2 offices are connected through a wan. I am curious is IPP still really viable? Again, just trying to learn a topic.
          • J_Arnold
            IT Director
            • Sep 2021
            • 87
            I agree with you, I stay away from IPP as well. I was just trying to help. Airprint uses the IPP and IPP2 protocol. You can use CUPS printers with your organization’s Chrome OS devices. CUPS uses IPP to print to local and network printers.
            Otherwise they use cloud based printing or PPD. Apple is pushing Aiprint on all of their devices. So I don't see it going away anytime soon. Last thing. I do not use Airprint. I use Lpd.
            • J_Arnold
              IT Director
              • Sep 2021
              • 87
              Also.. any chance you can show me steps for Ip printing from a Chromebook? That would be a great asset for my mental toolbar. Thanks.
              • PrintWhisperer
                • Feb 2018
                • 472
                Kyocera Mobile Print is available in the Google Play store for Chromebook, perhaps the manufacturer of your machines makes a similar app.
                Works for print and pull scan, but only from the app. Prints from app launched web browser or with file browser.
                "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
                • J_Arnold
                  IT Director
                  • Sep 2021
                  • 87
                  Oh they do. I also use PaperCut mobility print if worse comes to worse. I was just wanting to know how to IP print from a Chromebook.
                  I don't have an issue with Chromebooks or Macs printing. I was just helping the guy who does.
                  Edit:Oops, I mainly work with Toshiba and some HP and Brother devices.
                  • tonerhead
                    • Sep 2009
                    • 582
                    Here they are
                    1. Click clock area in lower right to open settings icon (gear cluster)
                    2. Open settings
                    3. Click "advanced" dropdown
                    4. Open "print and scan"
                    5. Open printers
                    6. click "add printer" icon to right of add printer
                    7. You should see add printer manually. Put in name, "address" is ip address of printer. On "protocol" dropdown select AppSocket (tcp/ip), select add
                    8. Advanced printer configuration dialogue box opens. Select the manufacturer and model or provide a ppd. Then click "add" and you are done.
                    Again, usually you only get minimum configurations like color/bw, duplex. I haven't done a chromebook using access codes for a while, but the last time I did it wasn't available. You had to print to a print server which relayed the access code to the printer.
                    • J_Arnold
                      IT Director
                      • Sep 2021
                      • 87
                      Here they are
                      2. Open settings
                      5. Open printers
                      Thank you. I will definitely give that a try, and you are correct. Toshibas still have no feature access.
                      • tonerhead
                        • Sep 2009
                        • 582
                        Over the years it seems like every IT person I run into wants to use LPD port for Macs. Even the IT techs we have want to use LPD for the port. I often ask why, no one can give me an answer why. In a Windows world printing started on a com port, then moved to lpt port. When networking came along they needed to go from parallel to network printing so along came lpr (which uses lpd). Then finally came IP or hostname printing. LPD is old technology. Macs have the ability to print IP so why not use it? LPD protocol is just a translator which coverts parallel printing commands into commands that can be sent down ethernet. According to Wiki, LPD started 39 years ago. I wish I knew why we are still using it or what the advantage to using it is.
                        Side note: I had a cop shop that had to print from their squad cars to a printer in the station (small, 4 cops total). So their IT did a port forwarding of port 9100. Within a day or two, some script kiddie hacker figured that out and would print off pirate faces to their printer. So they came back to our company and said we had to come up with a solution or they were going to start looking elsewhere for something that would work. The first thing I told them to try was port forward 515 and use lpr protocol for printing. Worked fine, script kiddie didn't figure it out. No longer work for that company, but I believe the cop shop is still using that idea. In my mind it was stupid in the first place, they should have been using a vpn but weren't.
                        • PrintWhisperer
                          • Feb 2018
                          • 472
                          Over the years it seems like every IT person I run into wants to use LPD port for .....
                          Ports and drivers are 2 different issues, and unless you are doing some special printing it doesn't matter what port monitor you use as long as the device supports it. For the OP, driver support in the target OS is where the issues come up he's just focused on the wrong thing looking for Windows like support in home devices.
                          Fact is even Windows V4 printing is moving in the 'austere built-in driver' requiring additional app support as MAC and Linux platforms and IPP/IPPS for cloud printing so may as well learn the new meta.(See MS V4 Printer Extensions/MS Universal Print)
                          LPR/LPD is the Unix derived protocol (in my 1988 college class it was used for serial printers) and hence MAC OS-(linu)X is grounded in it. It provides flow control and error checking outside of the TCP protocol that Port 9100 does not.
                          Port 9100 also suffers due to FIFO if multiple hosts print simultaneously, particularly if one is sending a big job. The first in places all other incoming hosts on TCP Keep-Alive and the unit stops receiving their print data. This would make it the worst port type for a busy unit with multiple hosts printing like a bunch of tablets.
                          BTW Windows LPR port monitor can be added in Server Roles or Windows Features by adding Print and Document Services.
                          LPR/LPD allows multiple print channels on the same port number by defining the additional parameter of 'queuename'. This allows alternate processing routes such as is seen on Fiery where they use LPR/LPD for the Print/Hold/Direct queues. MyQ uses it to identify all their queues for routing.
                          • J_Arnold
                            IT Director
                            • Sep 2021
                            • 87
                            Well thought out and excellent post. Thank you.
                            • tonerhead
                              • Sep 2009
                              • 582
                              Thank you for explaining it. You are the first to explain it to me.
