Duplicate printer IP address
    • 16393
    Re: Duplicate printer IP address
    One last thing. We can tell a switch to only learn 1 mac address for a port or several macs. If an unauthorized device is plugged in, we can use 3 different violation modes:
    1. Shut down - the port is shutdown and an admin must turn back on.
    2. Protect - This simply mean that the switch will not put anymore mac addresses in its CAM table and no packets will be forwarded except on authorized devices. Protect mode doesn't generate an alert message or email.
    3. Restrict - Lets only authorized mac addresses communicate on the network and generates alert messages and logs. (it keeps a daily log of port activity. )
      • 37502
      There's another way to do this and it's probably the best method, IMHO. You can bind a mac address, or two, to a specific port on the switch. If someone comes along and plugs in a laptop or other device, the port immediately shuts down and the IT dept is notified via email.
      You can also do some other cool stuff but we'll save that for another day.
      And if the main company network also includes WiFi, you can also block devices by their mac, or to be more precise, you can only allow specific devices, even on home WiFi networks. Of course there are a lot of so called IT people out there who do not know or do not care. We have all encountered them. Think they are better than a lowly copier man until one of us determines the cause of a network problem in less than 5 minutes that they have been working on for hours.
        • 16393
        True. You probably remember me talking about this on the board. I set up several lightweight access points and a WLAN (Wireless LAN Controller) on a Radius Server. It's basically Active Directory for Wireless. You sign in to the wireless network with the same credentials and only have access to the information that was granted to you. The Lightweight Access Points don't do any of the heavy lifting. It's all done on the WLAN controller and you can control everything from there.
          • 23008
          #19
          Maybe I don't understand all the variables, but "Restrict" seems like the best option to me. It allows authorized activity, it blocks unauthorized activity, and it records data on a log. I think that covers all the bases. =^..^=
            • 16393
            #20
            That's the one that I like the best.
              • 37502
              #21
              One thing I have seen with local offices of large corporations is using managed switches to only allow things like printing only to specific ports.
                • 16393
                #22
                You can do so many amazing things with a switch. I fell in love with Cisco switches and routers. However, learning that stuff can be grueling and after some time I realized that I was never gonna use 99% of the stuff that I was learning unless I was planning to go to work for a large corporation one day. That's not in my plans. I'm too old for a career change so I put the CCNA down. I still go back and brush up on it and play around. It really amazing.
                  • 23008
                  #23
                  Only that would solve a lot of issues. Port 9100 open only. Hardly anyone uses port 9101, 9102, 9103, 9104 ... maybe leave the port open for SNMP: 161, 162? Printers wouldn't need anything other than 9100, 161, & 162. =^..^=
                    • 16393
                    #24
                    Switches only deal with Mac Addresses. Ports would be done at the router. It you wanted to block/limit printing at the switch level, it would involve creating an ACL (Access Control List) and we're getting in the deep end of the pool so I'll leave it there.
                      • 16393
                      #25
                      My apologies. slim said "managed" switch. That means it does routing.
                        • 23008
                        #26
                        You know, I've brought this up with IT folks before when they're getting non-print data hitting the printers IP, and I've always gotten that " ... it could be done ..." response. Maybe it's over the head of your average office IT guy. =^..^=
                          • 37502
                          #27
                          What I have encountered has been blocking those ports to locations not designated for printers. Works fine as long as everyone knows about it. Had a local office of a large oil field services company where the corporate IT had setup the switches and administered the network for as number of years until they decided it would be better to have a local IT person but failed to inform her about the designated printer jacks. Got a call one Monday morning that printer in their shop office was not working. Over the weekend they had moped all the furniture including the MFP out of the office so they could paint the office. It had a link light and we could ping it but it still couldn't print. Then I noticed that the network jack it was plugged into was the one I normally used when testing. We pulled the MFP out from the wall and there was another jack next to the power outlet. Moved the connection to it and the MFP immediately started printing everything that had been cued to it.
                            • 16393
                            #28
                            I know this isn't exactly what blackcat was talking about but I'll share anyway.
                            Let's say that we put the printer on a VLAN. That VLAN will be tied to a range of IP addresses on the same subnet. Basic stuff. Now we can configure the switch to allow or deny printing to certain users by blocking a IP address or addresses via ACL.
                            The syntax would look something like this:
                            ip access-list extended Printer_Allow
                            permit ip host 172.16.1.36 host 172.16.1.153
                            permit ip host 172.16.1.115 host 172.16.1.153
                            deny ip 172.16.1.0 0.0.0.255 host 172.16.1.153
                            permit ip any any
                            vlan access-map Printer_Allow_VACL 10
                            match ip address Printer_Allow
                            action forward
                            vlan filter Printer_Allow_VACL vlan-list 1
                            I think blackcat was talking about blocking unwanted network traffic at the port level??
                              • 23008
                              #29
                              Correct. That was what I had in mind anyway. I keep hearing that it's possible, but nobody does it.
                                • 37502
                                #30
                                I have met a lot of IT people like that. Had one drive over 100 miles from Los Angeles to Taft, CA to install a jack for a printer but didn't even bring half the equipment he needed. Then there was there was the one who could not figure that when some of the computers could not access anything and some could that it just might be have something to do with the computers, like whether or not they were turned off over night. He spent over 5 hours trying to determine which router wasn't working properly when the problem was the DHCP service on the Domain Controller had stopped. When I asked the receptionist to have him call me so I could tell him what I had found he told he was too busy so she had the corporate IT supervisor in Spokane call me. He then did a remote connection to the server and restarted the service. He then had the receptionist to announce for all those having network access problems to reboot their computers.
