SMTP settings in a printer
    Hi
    One of our customers has settings configured before delivery, things like default colour / b/w copy setting, ntp server address etc
    I had to do a few Kyocera pa5000 and didn't think there would be SMTP settings in a printer, I was wrong I could set the SMTP server address in the RUI ( command centre )
    I thought SMTP was only for sending scans to email, so why would there be settings for this in a b/w printer
    Re: SMTP settings in a printer
    I'm not familar with this printer but is it able to send a notification report via email?
      I don't know all it wanted was a default address and sender address, I put this here rather than the kyocera forum since it possibly applies to other makers.
      • rthonpm
        • Aug 2007
        • 2849
        It allows the printer to send email alerts for things like low toner, paper jams, or other issues that need intervention; it's handy for environments where SNMP or other monitoring isn't available. Some manufacturers also use it to permit automated metre submission.
          I've got one left to do, I will take a closer look at the smtp settings tomorrow.
            • 29913
            Originally posted by skynet
            Hi
            Yes Kyocera machines can send copy count toner and other reports via email in the command Center been that way for 10 years or more
            • anothertech
              • 1760
              There must be more SMTP settings to get this to work. It's going to need the SMTP server name or IP address. It will also need user name and password if they are using SMTP authentication. It needs all the same info as an MFP that's scanning to email.
              At least that's the way in is with Ricoh printers, I'm not 100% sure about this Kyocera.
                Yep and it also needs internet access (correct gateway) or it's never gonna work.
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  That would be my guess.
                  โ€œI think you should treat good friends like a fine wine. Thatโ€™s why I keep mine locked up in the basement.โ€ - Tim Hawkins
                    • 29913
                    OMG
                    Kyocera had this feature for for over a Decade in every printer and copier
                    Nothing new
                    You setup it the same as a copier
                    How embarrassing for someone who's supposed to be a dealer and has OEM training
                      • 37357
                      That information should come from the customer, I.E. their email provider.
                      Usually their ISP It needs all the same info as an MFP that's scanning to email.
                      You do not need to setup users and destinations. And it seems a lot simpler than @remote.
                        • 29913
                        OMG how about don't comment on shit you don't know
                          • 37357
                          You do all the time.
                            Dont ruin my posts outside of the rants forum, and fyi I am based in a workshop and usually don't get involved in this.
                              • 29913
                              Your post was technically answered correctly on the first page the rest is a waste of time from NON IT or NON Kyocera trained technicians
                              enjoy
