Dell 9010 no sound
    • 37597
    #16
    Re: Dell 9010 no sound
    I wondered if that may be the case but wasn't able to find anything on it. That would explain a lot. Thanks, slim.
    I had to replace a controller board because of a bad modem chip once. Could ping it or ARP it but could print or scan.
    • rthonpm
      • Aug 2007
      • 2859
      #17
      This is also why you want to check the audio status in the onboard diagnostics. If it doesn't work there, then the hardware is at fault.
      Sent from my Pixel 6 Pro using Tapatalk
        • 16491
        #18
        So, I just went to the onboard diagnostics in bios and ran the audio test. It played 8 different tones via the internal speaker. Is that the one you're talking about?
          • 16491
          #19
          PS - I did the audio test on my Dell PC, not the problem machine. I just wanted to check it out.
          • rthonpm
            • Aug 2007
            • 2859
            #20
            That's the one...
              • 16491
              #21
              That's the one...
              You mean that's all I had to do to determine it was or wasn't a hardware problem?
              That makes me feel kinda dumb.
              I will run that test on the problem machine tonight.
              • rthonpm
                • Aug 2007
                • 2859
                #22
                That's the whole point of diagnostic mode: it takes out the OS as a possible cause of the issue.
                  • 16491
                  #23
                  I ran the internal audio diagnostics on the problem machine and it worked. I heard the tones from the internal speaker. That means the likely problem is a corrupt operating system. I'm gonna try to repair it.
                    • 37597
                    #24
                    Start with Sounds in Control Panel.
                      • 16491
                      #25
                      I reinstalled Windows, drivers, bios and all updates. Still no sound. There's little doubt in my mind that this is a motherboard problem.
                      But I did plug the speakers into the monitor and now I have sound. Still no sound from rear or headphones and the RealTek drivers don't show up. The only drivers that are available are for the monitor.
                        • 37597
                        #26
                        In Control Panel - Sound on the Playback tab does it show both the monitor and the speakers as available options with a check mark on the monitor? If so highlight the speakers and click Set Default. When I connect my TV to my laptop using HDMI in order to watch a YouTube movie on the larger screen, it automatically defaults the playback to the speakers on the TV, much better quality sound.
                        • rthonpm
                          • Aug 2007
                          • 2859
                          #27
                          For the most part, that should be fine. It's not 1998 any longer: DisplayPort and HDMI both carry audio and video. The need for a headphone jack speaker set into a desktop is antiquated at this point and offers all of the drawbacks of an analogue device: static, poor connection, etc.
                            • 16491
                            #28
                            It only shows the monitor.
                              • 16491
                              #29
                              Hey, man, thanks for all of your help. I learned a lot from you on this.
                                • 16491
                                #30
                                PS - Thanks to everyone for your help. I appreciate it.
