Re: How to grab Wifi passwords with only 2 commands
Win + Ctrl + O (the letter not the number) will turn on the On Screen Keyboard. It is a lot more convenient than an external key board. I have been using it for some time now because the i, y, l, the 0 on the ten key and the Enter key of the main key board quit working.
I will try it, but my desktop doesn't have Wi-Fi, my laptop does, but I cleaned the keyboard last week, and now it just repeats a certain key, kind of difficult putting the password in. Ordered a new one last week.Leave a comment:
Got a question, can either of them be used on a Mac?Leave a comment:
nmcli should be supported by most ubuntu and redhat versions. Debian i am not too sure aboutLeave a comment:
So glad the Linux world made nmcli all but a standard. It's a pain having to remember what tools work on what distribution.
Sent from my Pixel 6 Pro using TapatalkLeave a comment:
It's more than just changing the string. You're using native Windows commands like netsh which aren't understood by Linux. It would be like trying to get a script calling chkdsk to work in RHEL: it's not going to know what you're trying to do.
On linux it would be smarter to just do it with a python script. I quickly translated this code so forgive any mistakes:
Code:import subprocess wifi_profiles_info = subprocess.check_output(['nmcli', '-t', '-f', 'SSID', 'connection', 'show', '--active']).decode('utf-8') wifi_profiles = [line.strip() for line in wifi_profiles_info.split('\n')] print("Available Wi-Fi networks:") for index, profile in enumerate(wifi_profiles): print(f"{index + 1}. {profile}") selection = input("Select a Wi-Fi network (enter the number): ") try: selected_profile = wifi_profiles[int(selection) - 1] except (ValueError, IndexError): selected_profile = None if selected_profile: wifi_password_info = subprocess.check_output(['nmcli', '-s', '-g', '802-11-wireless-security.psk', 'connection', 'show', selected_profile]).decode('utf-8') wifi_password = wifi_password_info.strip() print(f"Wi-Fi network: {selected_profile}") print(f"Password: {wifi_password}") else: print("No Wi-Fi network selected.")
Last edited by techsxge; 10-06-2023, 01:13 PM. Reason: Updated script as netsh does not exists on linuxLeave a comment:
not too sure if powershell is 1:1 supported by linux.
In any case bin/sh would be for shell scripts, not powershell scripts.
You would need to add:
#!/usr/bin/pwsh -CommandLeave a comment:
I made a script that will let you extract the passwords from any recently connected wifi to just simplify this.
Script:
https://github.com/vlc3n/FuckUrBatch...fipassword.ps1
Compiled to exe:
Release wifiPassword.ps1 compiled to .exe * vlc3n/FuckUrBatch * GitHubLeave a comment:
Script:
Collection of batch and powershell scripts for free use. Credits to a book i got gifted from a book shop 3 years ago that got me interested in batch scripts - vlc3n/FuckUrBatch
Compiled to exe:
Its open source, so you dont have to worry about any bloatware being installed or the script doing shady things.Last edited by techsxge; 10-06-2023, 01:04 PM.Leave a comment:
yeah that works well, have used it before. only works though if the person has connected once to the network. then they forgot the password. and for whatever reason was disconnected. run both of those commands and you have the info you need. you can blow someone's mind with that trick. lolLeave a comment:
