How to grab Wifi passwords with only 2 commands
    • 15238
    I thought this was pretty cool.
    This first command can show us all the wifi profiles stored on a windows pc.
    netsh wlan show profile
    This second command can show us all the wifi passwords
    netsh wlan show profile name="name of wifi" key=clear
    Give it a try.
    • 35265
    Re: How to grab Wifi passwords with only 2 commands
    I use a freeware WiFi password revealer from magic jelly bean. It allows one to export the results to a text of CSV file. As with all freeware use caution and have a good virus protection software.
    • tsbservice
      Field tech
      • 7712
      Give it a try.
      Sometimes users don't have any clue what the wifi password is. It will help, Thanks Billy.
      • techsxge
        • Jan 2022
        • 661
        I mean yeah its a fancy command but not realy practical as you can just click your way through to see the password.
        Anyways, want to do it without user input?
        Code:
        (netsh wlan show profile name="$(netsh wlan show interfaces | Select-String 'SSID' | ForEach-Object { $_ -replace '^\s+SSID\s+: ','' })" key=clear) | Select-String 'Key content'
        Might work, have no wlan to test it out rn. Should grab the currently connected Wlan connection and output the password though.
        Powershell command, wont work in cmd.
        • dalewb74
          • Feb 2018
          • 1080
          yeah that works well, have used it before. only works though if the person has connected once to the network. then they forgot the password. and for whatever reason was disconnected. run both of those commands and you have the info you need. you can blow someone's mind with that trick. lol
          • techsxge
            • Jan 2022
            • 661
            I made a script that will let you extract the passwords from any recently connected wifi to just simplify this.
            Script:
            Collection of batch and powershell scripts for free use. Credits to a book i got gifted from a book shop 3 years ago that got me interested in batch scripts - vlc3n/FuckUrBatch
            Compiled to exe:
            Release wifiPassword.ps1 compiled to .exe * vlc3n/FuckUrBatch * GitHub
            Its open source, so you dont have to worry about any bloatware being installed or the script doing shady things.
              • 2621
              Script:
              https://github.com/vlc3n/FuckUrBatch...fipassword.ps1
              Compiled to exe:
              Can I add #!/bin/sh to the beginning of that script for Linux?
              • rthonpm
                • Aug 2007
                • 2848
                No.
                Sent from my Pixel 6 Pro using Tapatalk
                • techsxge
                  • Jan 2022
                  • 661
                  not too sure if powershell is 1:1 supported by linux.
                  In any case bin/sh would be for shell scripts, not powershell scripts.
                  You would need to add:
                  #!/usr/bin/pwsh -Command
                  Last edited by techsxge; 10-06-2023, 01:03 PM. Reason: replaced powershell with pwsh
                  • techsxge
                    • Jan 2022
                    • 661
                    On linux it would be smarter to just do it with a python script. I quickly translated this code so forgive any mistakes:
                    Code:
                    import subprocess
                    wifi_profiles_info = subprocess.check_output(['nmcli', '-t', '-f', 'SSID', 'connection', 'show', '--active']).decode('utf-8')
                    wifi_profiles = [line.strip() for line in wifi_profiles_info.split('\n')]
                    print("Available Wi-Fi networks:")
                    for index, profile in enumerate(wifi_profiles):
                        print(f"{index + 1}. {profile}")
                    selection = input("Select a Wi-Fi network (enter the number): ")
                    try:
                        selected_profile = wifi_profiles[int(selection) - 1]
                    except (ValueError, IndexError):
                        selected_profile = None
                    if selected_profile:
                        wifi_password_info = subprocess.check_output(['nmcli', '-s', '-g', '802-11-wireless-security.psk', 'connection', 'show', selected_profile]).decode('utf-8')
                        wifi_password = wifi_password_info.strip()
                        print(f"Wi-Fi network: {selected_profile}")
                        print(f"Password: {wifi_password}")
                    else:
                        print("No Wi-Fi network selected.")
                    Last edited by techsxge; 10-06-2023, 01:13 PM. Reason: Updated script as netsh does not exists on linux
                    • rthonpm
                      • Aug 2007
                      • 2848
                      It's more than just changing the string. You're using native Windows commands like netsh which aren't understood by Linux. It would be like trying to get a script calling chkdsk to work in RHEL: it's not going to know what you're trying to do.
                      • techsxge
                        • Jan 2022
                        • 661
                        Code:
                        import subprocess
                        try:
                        else:
                        Updated this code as netsh is not available on linux, my bad
                        • techsxge
                          • Jan 2022
                          • 661
                          yep, i updated my script to not use netsh. Saw this myself after uploading it... Now it uses nmcli
                          • rthonpm
                            • Aug 2007
                            • 2848
                            So glad the Linux world made nmcli all but a standard. It's a pain having to remember what tools work on what distribution.
                            • techsxge
                              • Jan 2022
                              • 661
                              standardisation is like the biggest thing holding people back on using linux i feel like.
                              nmcli should be supported by most ubuntu and redhat versions. Debian i am not too sure about
