Text commands to change printing defaults
+ More Options
Posts
  • jneezy2008
    Software/IT
    • Mar 2009
    • 72
    I know how to add printers using text commands in Command Prompt but how can I change printing defaults, such as changing the driver from color to black and white, using text commands? Is that possible?
    The snozberries taste like snozberries!!
    • 22989
    If you are referring to a Copystar or Kyocera Mita machine, both of these use PreScribe commands to change these settings. The use of PreScribe is by-no-means universal, so the big question is:
    What kind of equipment are you working on? =^..^=
    • jneezy2008
      Software/IT
      • Mar 2009
      • 72
      Konica Minolta C451 and C253.
      • jneezy2008
        Software/IT
        • Mar 2009
        • 72
        Turns out that all you have to do is set your defaults in the print driver, then export the .dat. You can't really change the defaults using command prompt.
        • TheOwl
          • Nov 2008
          • 1732
          Where did you export the .dat file from?
          Normally I would install the printer on a server, set the 'Printing Defaults' and then if you install the driver using the command prompt or run a VB script, it will drag down the settings that are set on the server.
