Direct CSV import of scanner destinations
  • mrwho
    Major Asshole!
    • 4299
    Good afternoon all.
    Is there any brand/model of MFP that will allow direct import and export of address book data into .csv files without the need of proprietary software?
    Thank you.
    Mascan42
    Ibid
  • wav
    • Oct 2021
    • 285
    Re: Direct CSV import of scanner destinations
    hi,
    see this it maybe helpful
    Import/Export (hp.com)
    Importing the Address Book of the Machine | User Guide | IM 350, IM 430 (ricoh.com)
    [SETTING MODE]|System Control|BP-70M65|09-07_021|manual download|MFP / Copier / Printer products|Office solution: Sharp (global.sharp)
    • rohit34hj
      • Jan 2024
      • 2
      Since you have multiple rows of items in your file NS doesn't know if you want them all in 1 transaction or separate transactions. Since you are doing ADD here, you need to provide a Document# or ExternalID that is the same on all rows that you want grouped together onto 1 transaction. If you have auto-numbering turned on and you disallow overrides, then the Document# you import here won't actually be saved onto the transaction (because it will get an auto number instead) but the CSV importer will use the Document# to know what rows you want batched together onto the same 1 transaction.
      • dalewb74
        • Feb 2018
        • 1153
        many of them will allow export import, but not between different brands. and some won't allow if the age difference is a few years different. i don't know of any that uses actual csv file.
          • 37491
          I don't know about other manufactures but Ricoh has a way to convert their WIM export file to a csv file. I had to use it once for a customer who wanted to have the same address book on the their MP C3503s and on their computers that were using LAN Fax.
          • rohit34hj
            • Jan 2024
            • 2
            9apps apk
            • rrrohan
              • Sep 2011
              • 1977
              if you can print out the address list you can take a photo then use the excel option of import data from image
              it will OCR the text and then you can make your own CSV file
              • Hart
                • Feb 2024
                • 406
                Sharp can do it natively on the newer units (CR4.5 at least).
                Old method with proprietary format
                New method with standard CSV
                • Saturn
                  • Nov 2023
                  • 171
                  From the IM series onwards you can download the address book directly as a .csv file. If we need a .csv file from older Ricoh models,
                  we save the address book as a xxxxxxx_addr.udf file, import it onto an IM machine and save it as a .csv file.
                  I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
