Fiery repeating the same job constantly even after restart
  • nullskull
    Learning
    • Aug 2023
    • 437
    Hello I have an old fiery pro-80 connected to a Konica Minolta C7000. A few days ago a glitch started where a certain job somehow started to repeat constantly. The job can be deleted from the printer's queue and from the fiery software but no matter what it consistently reappears. I have of course restarted the fiery, the computer that sent the job and the printer itself. Even after multiple times the problem always seems to return eventually. I have also used the fiery software to "clear server" multiple times. (I only checked the top two boxes before running) I don't really know for sure as I have little experience with fiery but could something in the fiery server itself be corrupted? Any suggestions? Oh and the error connected occasionally to the glitched jobs that keep appearing is (PS typecheck error, offending command "image") This will show up on the copier itself occasionally but the fiery app more often.
    • 37521
    Re: Fiery repeating the same job constantly even after restart
    What happens if you turn the computer that sent the job OFF and leave it off or disconnect it from the network?
    • nullskull
      Learning
      • Aug 2023
      • 437
      Ok I will try that and let you know what happens.
      • nullskull
        Learning
        • Aug 2023
        • 437
        So i tried that and the document stopped loading until i turned it back on again. So what do you think i should do next?
        • ntbann
          • Jan 2012
          • 628
          You could stop the print spooler on the pc and restart it. This may help.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            You may also want to clear all the files from the spool queue on the PC, as well.
            It should be located at: C:\Windows\System32\spool\PRINTERS
            BTW... ".spl" files are "spool" files, while ".shd" are "shadow" files, which allow the spool files to resume processing should they get interrupted somehow.
            • nullskull
              Learning
              • Aug 2023
              • 437
              Hey thanks. This worked for me
