RICOH MP C5504 Issues When Connected through Wi-Fi Connection in Interface Settings.
  • Shah168
    • Jan 2024
    • 4
    I have RICOH MP C5504 connected through Ethernet Cable. I have installed printer and Scan-To-Folder without any issue.
    My Issue:
    When MFP is connected via Machine Network in Interface settings, Everything works fine.
    But when MFP is connected via Wi-fi Connection in Interface Settings, it only prints (MFP not accessible via Web Interface, Scan-To-Folder doesn't work).
    Any Help will be appreciated.
  • techsxge
    • Jan 2022
    • 660
    Re: RICOH MP C5504 Issues When Connected through Wi-Fi Connection in Interface Settin
    Wifi Network is probably port restricted / port locked so that doesnt work. Try to contact the Customers Network Administrator for help. Web interface on some machines from other manufacturers sometimes do only work with ethernet connection
    • Elmo
      • Feb 2010
      • 541
      This machine does not have built in wifi
      you would need to fit the optional wifi kit
      What type of wifi device have you connected to the copier ?
      I Used To Live To Fix Things Now i Fix Things To Live
      • anothertech
        • 1771
        He say's he's printing with wifi, something is connected.
          • 37521
          The SOP does have limited WiFi that does allow printing ONLY.
          • Shah168
            • Jan 2024
            • 4
            MFP has built-in Wi-Fi and it connects seamlessly with our Wi-Fi Router.
            • Shah168
              • Jan 2024
              • 4
              Is there a work around?
              • Elmo
                • Feb 2010
                • 541
                you can use a wifi extender then ethernet cable from it to copier.
