IR 5000/6000 connect to PC
  • irwan zamroni
    • Dec 2007
    • 12
    help me
    i want to connect my IR 5000 to PC with LAN cable,
    some body help me ,plz
  • Tim C
    • 167
    Is you IR5000 print ready? Does it have a Nic Card? When you press Additional Fuctions button, do you see a network settings, and a Printer Settings touch button? Then, if you have these options installed are you hooking it to a network or directly to a pc
    • irwan zamroni
      • Dec 2007
      • 12
      it's ready to print, and i have connect it to pc via LAN card
      i just want to know how is the way i must do, step by step.
      until now i have do this :
      1. i have setup using installer 5e
      2. i have set ip of machine : 172.16.11.5
      and subnet mask : 255.255.000.000
      3. i set my PC IP : 172.16.10.5
      and subnet mask :255.255.000.000
      and i tray to ping 172.16.11.5 , but that data was lost
      any respond?
      • costcotoner
        copier toner cartridge factory
        Originally posted by irwan zamroni
        help me
        we can produce any barnds copier toner cartridge ,such KYOCERA,CANO,SHARP,PANASONIC,RICOH,Minolta,HP.we can supplier the good quality with competitive price
        Costco Toner Industrial Co.,Ltd
        Address:1707-4 N596 BaiLaoHui Building TianHei Road GuangZhou
        Guangzhou office Tel:0086 20 88262402 Fax:0086 20 88262403
        Sales:Ray Liang
        mobile phone:008613751718757
        email/MSN:ray@costco-toner.cn
        Skype:costco-toner
        www.costco-toner.cn
        • irwan zamroni
          • Dec 2007
          • 12
          HEY THIS OUT OF TOPIC
          • costcotoner
            friendship
            yes,can we be friend?
            • costcotoner
              do you have msn ?
              • irwan zamroni
                • Dec 2007
                • 12
                just mail me : irwan_zamroni@mail.com
                • Tim C
                  • 167
                  Are you using a Crossover Cable? A standard Ethernet cable will not work.
                  If you are you still may have to flash the machine with canon system software . Yopu could also try a MMI clear in service mode.
                    • 23010
                    any respond?
                    I see a mistake right away.
                    For your printer to be on the same network, your PC needs to be at any address: 172.16.11.xxx For example: 172.16.11.3
                    With your PC at 172.16.10.5 it's on a different subnet and will not communicate or ping. =^..^=
                    • time2fly
                      • Jul 2008
                      • 134
                      Your IP address is wrong the third octet is wrong make sure that all but the last octet is the same and your subnet mask all have to be the same. Use a crossover cable if you are going straight from the PC to the copier.
                      • Tim C
                        • 167
                        You are using a CROSSOVER CABLE right?> Well the only thing left to do, with replacing parts is to do a System Flash. You must have service tool and the specific 5000/6000 data to do this. Sorry I can no provide this for you.
                        • irwan zamroni
                          • Dec 2007
                          • 12
                          thanks all senior,
                          my IR 5000 has connect to my PC
                          actually it cause of :
                          1. my windows XP is trial version, i reinstal using SP 2
                          2. ip setting for machine : 172.16.10.3
                          for my pc 172.16.10.4
                          and sm both are 255.255.000.000
                          i tray to ping 172.16.10.3, no data loss
                          thanks all
                          • mrfixit51
                            Lead Service Technician
                            • Oct 2008
                            • 1975
                            I may be mistaken,, and if I am,, somebody educate me
                            Hi blackcat! Initially I thought the same thing, that would be true if his subnet was 255.255.255.0 That signifies a class C network, and all but the last octet have to be the same. But his reported network is 255.255.0.0, which is a class B network, I believe only the first two octets have to match. This allows for a far greater number of network address' to be available. But on a small network, class B makes no sense.
                              • 23010
                              Thanks for the correction mrfixit. I don't see many class B addresses, so that slipped right by me. =^..^=
