Low cost DCA tool
    • 8171
    Low cost DCA tool
    Can anyone recommend a low cost Data Collection agent for small dealers with small fleets of copier/ printers for mostly low volume devices.
    I know Lexmark has their Fleet Mgt Cloud portal to collect meter reads but I do not have access to it.
  • Duplicator
    • May 2022
    • 245
    Re: Low cost DCA tool
    We use something called Labrador. It uses SNMP to collect data from the copiers/MFPs/printers/ect. It works....okay....
    Labrador Solutions, LLC.
    It's got a few upsides.
    • Seems to collect meter counts reliably. Reports them in a web interface.
    • There is a customer and "admin" side. If needed you can give the customer access to see what their collected counts are.
    • Doesn't seem to cost much compared to other options.
    • Server outages seem to be rare.
    It's drawbacks are numerous however.
    • It pretty much hasn't been developed since the Windows 7 days.
    • Doesn't update meter counts correctly in the ERP. (so we can't use it's automatic function). It calculates "Impressions" as just the B&W prints, not B&W+Color prints.
    • Would be nice to have a way to see consumable levels, firmware version, error codes, or other metrics.
    • There is ONLY a Windows client. No options for macOS or other OSes.
    • Windows client interface is really clunky to use.
    • Communication can be poor from the company behind it.
    I suppose you get what you pay for.
    • Seems to be run by one guy with one rented server. This might not be true but it sure feels like it.
    Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
    If I helped you out, please give me a thumbs up! It helps my reputation.
    • plus-COPY
      • Aug 2023
      • 26
      MFP-SERVICE
      For Canon and Konica Minolta, we use a program that does not require DCA to be installed.
      The configuration is uploaded to the devices in service modes, and the device will send information from any location.
      The program consists of the Administrator, system users and the client with granted permissions.
      I recommend it, very convenient to implement, developed since 2007.
      • Hart
        • Feb 2024
        • 391
        What ??? We've been nagging Canon for years to have an integrated solution like Sharp (or Epson now with ERS).
        • mbcruzin
          • Aug 2013
          • 142
          I have used several at this point
          FSM Fleet Services Management. This was a nightmare to keep up and running on the client side
          PA Print Audit. Another nightmare....
          KFS Kyocera Fleet Services. amazing for Kyocera and copystar fleet management.
          Now EKM..... Haven't figured out the acronym yet. From what I've seen it works amazing with HP devices. had a few issues with correctly reading Kyocera and Toshiba 3 tier meters. Plus the algorithm takes a few months to figure out the customer usage for toner requests.
          The best one for me was Kyocera fleet service/KFS. It allowed us to have almost full control over the Kyocera/copystar fleet. Push firmware, collect meters, toner usage, clear errors, perform system settings without being in front of the machine, and more. It even had a DCA for non-kyocera/copystar devices that worked well enough. However I was told the cost per machine was getting out of control. That is why we switched over to EKM
          • Mick C
            • Mar 2011
            • 9
            I would like to see a third party system that doesn't require software install on clients network, we have Ricoh and Sharp brands, Ricoh is great with the "@ Remote " system as it is all set up within the machine and Ricoh's server and just needs to be able to get out through the network, Sharp's MICAS I won't even touch as it is set up on customers network, just prone for failures.
              • 37422
              Even @Remote can be blocked by the customer's firewall. Often the fear of corporate espionage can have a network locked so tight that you can't get anything out.
              • GBell
                • May 2024
                • 2
                EKM Predictive Insights is pretty darn nice...
                It's way more than a DCA. It will show which accounts are changing toner early, has HP predictive & JAMC built in all in a nice dashboard
                  • 8171
                  • smith121
                    • May 2024
                    • 1
                    Dollar-Cost Averaging (DCA) is a strategy for investing where you consistently invest a fixed amount of money at regular intervals, regardless of market conditions. While there are several tools available for DCA investing, here are a few low-cost options:
                    1. Robo-Advisors: Many robo-advisors offer DCA as part of their investment services. These platforms use algorithms to automatically invest your money across a diversified portfolio of assets. Some popular low-cost robo-advisors include Betterment, Wealthfront, and M1 Finance. FM WhatsApp
                    2. Online Brokerages: Many online brokerages provide tools and features that allow you to set up automated investments on a recurring basis. Platforms like Vanguard, Fidelity, and Charles Schwab offer low-cost brokerage accounts with DCA options.
                    • rrrohan
                      • Sep 2011
                      • 1977
                      what solution does sharp offer?
                      I know Konica Minolta has CSRC and HP has SDA but as far as i knew Sharp had nothing and we been relying on email notifications
                      • Hart
                        • Feb 2024
                        • 391
                        They have SRDM but it's trash so we use email, and it has been more than enough for us (we're moving to Kpax soon).
                        I don't understand why some brands refuse to implement email.
                          • 8171
                          Toshiba Canada has free eCloud Connect aka in the USA Elevate Sky Management. It is not as powerful as something like FM Audit which can import meters into a billing system.
