USB based utility to set static IP address
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    #16
    Hi, Blackcat,
    Yer almost there
    Now that you have the printer's IP,
    Arp -a <ip address> will show you the mac address of the printer.
    Example: arp -a 192.168.1.150
      • 23008
      #17
      I'm not feeling so brilliant just now.
      My victim today was a CS-2560 connected via crossover cable, with the laptop set to a similar IP range.
      Experiment #1: With Wireshark running I sent out the arp -s command as specified: JSmith>arp -s 192.168.0.20 00-C0-EE-1C-EF-9D then Enter.
      Nothing shows on Wireshark. After 2 minutes I powered the printer Off/On. Wireshark picked up the old IP address. I tried this with DHCP/BOOTP (they enable both with the same switch) both Off and On. No luck.
      Experiment #2: With Wireshark running, I fired up BootP Lite, filled in the lines as specified (the MAC address only works with colons), then OK. Wireshark picked up an ARP request from my PC "What is 192.168.0.1?" (which is the gateway) three times then nothing else. Next I powered the printer Off/On. The printers IP address did not change. I tried this with DHCP/BOOTP both Off and On. Again Wireshark picked up only the old address.
      Experiment #3: With Wireshark running I sent out the arp -a command as specified: JSmith>arp -a 192.168.0.10 then Enter.
      Nothing shows on Wireshark. Command prompt shows "No ARP found."
      These commands/utilities sound so simple. How could I be screwing this up? =^..^=
      • D_L_P
        Self Employed
        • Oct 2009
        • 1196
        #18
        When you did experiment #1 did you try the ip in internet explorer?
        With the ARP command, you are just adding an entry in your local computer not really changing anything on the printer. After you add the entry to the ARP table you should be able to bring up the web interface with IE or Firefox.
        ARP table is very similar to editing the hosts file. You sort of trick your computer to seeing that MAC address as the IP you gave it, not the one setup in the printer itself.
        On a side note, just in case anyone is curious, you can block websites by editing the C:\windows\system32\drivers\etc\hosts. Add an entry such as, "127.0.0.1 www.trojans4you.com" to block that site. Sorry, if you already knew this.
          • 23008
          #19
          Thanks DLP. I'm beginning to understand.
          Does anyone have a good written explanation of the typical command prompts? I'll see what Google finds... =^..^=
            • 23008
            #20
            I had the perfect opportunity to try out my new toys.
            Samsung CLP-600N with a yellow toner empty LED. Won't print so I can't get the IP from the config page. I fired up Wireshark then the printer. Wireshark identified 192.0.0.192 (typical Samsung default IP). With the laptop set to the appropriate IP range, I could access the web interface via IE. From here I can access or change anything I need to.
            But I still can't print without toner. That's probably why the printer is in here.
            By the way, I found a website with a great beginners guide to command line. See: Beginners Guides: WindowsXP Command Prompt - PCSTATS.com
              • 23008
              #21
              If anyone is still interested, I finally found what I was looking for. It's called SetIP (ver 1.03.24), and I found it buried on a manufacturer's driver disk.
              download centre SAMSUNG
              It definitely works on Samsung products, I haven't tried it yet on other manufacturers. It checks all ports, USB and TCP/IP.
              Hans, it looks a lot like your BootP Lite utility, possibly dressed up with different art. I wonder if the utility could be designed to look for a specific range of MAC addresses or ignore other MAC addresses outside the range, to make the utility manufacturer specific? The first 6 characters of the MAC address identify the manufacturer. If it's not encrypted, this is a great opportunity to open the executable in TextPad and identify the differences. It's probably encrypted. =^..^=
              • Vulkor
                • Jun 2009
                • 946
                #22
                Interesting Find. Not sure when I would need this, but if you try it on something non samsung let us now. FYI some Ricoh Printers are Samsung lol
