Ricoh 2051SP Printing Issue
  • Kamelboi711
    Network Specialist
    • Mar 2008
    • 22
    Hi All,
    I am working on Ricoh 2051SP that i am trying to setup printing. I have all the right setup on the machine. I can ping and get into the Web page with out any issues. But when i try to print a test page, it just sits in the queue and errors out even from my laptop with crossover. I have changed the NIC thinking that may be just a bad NIC but no luck. I have format the HDD, Cleared the Memory under Service Mode but still no luck. When i change the whole controller, it started working fine. If you have any ideas, please help me...
    Thanks in Advance.
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Originally posted by Kamelboi711
    Hi All,
    Thanks in Advance.
    If you changed the controller and it started working, why are you asking for help?
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • Kamelboi711
      Network Specialist
      • Mar 2008
      • 22
      I was just testing out from a different machine. I really don't want change the whole controller.
      • mikadonovan
        • May 2008
        • 2931
        Unfortunately controllers do occasionally fail. You can send it for repair to a company like Hytec for less than the cost of a new one. Another option is to use a boot SD card P/N B6456090. It is used to boot when the controller data becomes corrupt. I don't know if it will resolve your particular problem, but it may be worth a try as they are not that expensive. The procedure is covered in tech bulletin 091R for the B140 series.
        NEVER ASSUME ANYTHING
        • unisys12
          • 490
          Have you tried reloading/updating the firmware? At this point, it's the only way for sure to know it's a board and not a software issue. Do it all too, not just one or two things. Sometimes, for updates to load properly, you have to have other sections of firmware updated as well, so just load all the latest and greatest.
          sigpic
          The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
