Drivers for a verbatim ss600 scanner
+ More Options
Posts
  • auburn business systems
    owner/technican
    • Mar 2009
    • 46
    Looking for drivers this scanner. IT is also a mitcubishi chemical ss600. Hope some one has a link for the driver. Thanks howard
  • OMD-227
    A quick Google search found this.....
    SS600 - Device Driver Download
    Seems to be the one. Wasn't hard to find. Took about 30 seconds!
    Good luck
      owner/technican
      • Mar 2009
      • 46
      will that is NOT the driver for this scanner. it is a pay site for total scan on your system. i have checked out just about every thing on the net for the drive. about 1 hour. thanks for the 30 looking up. howard
      • OMD-227
        OK, OK...... just trying to help out chief.....
        I took another look around. It appears that a program called VueScan Pro (which is FREELY available to download) is a fully functioning operting driver/program for your scanner. It actually shows several hundred scanners it is compatible with as well. It doesnt mention anything about needing a special SCSI driver, so maybe look into it.
        Otherwise, have you though about just using a basic HP SCSI driver like the good old ScanJet 5P? Or a simple TWAIN driver?
