Change ip address on sharp ar-m237 - without password
  • smpb
    • Jul 2025
    just got a used sharp ar-m237 from a bankrupt company - need to change ip address but it has an unknown password - tried changing local machine to logon thru browser - i can logon but cannot change ip address because of password - please help - any suggestions appreciated. Also cannot use
    factory default settings for key operator code changes
  • OMD-227
    You can view what the admin/default password has been changed to, by checking sim 22-07. That will show you what the current admin password is. Once you have that, you can then log in and change it to whatever you want.
    • ZOOTECH
      Senior member of CRS
      • 3375
      "tried changing local machine to logon thru browser - i can logon but cannot change ip address because of password"
      In browser, login is admin, password is Sharp (case sensitive).
      Wazza is correct (as always) 22-7 gives the current password for the key op code..
      • xmasvn
        • Jul 2009
        • 70
        how a bout admin password when we go to Sim, i have one when i log in to Sim this request i login id and pass but this id and pass not use for the operation setting, So any one have idea of this one ...???
