Bizhub 350 Scan-to Email
  • herdless
    • Aug 2010
    • 10
    I'm trying to set up a BIzhub 350 for scan to email. I've talked to the customer's IT people several times and have had no luck getting it working. The only thing that I can't figure out how to do is turn on SMTP over SSL. Their IT guy says this must be done but I see no setting or softswitch to do this. On newer Bizhubs it is clear how to set this. Does someone know how to do it on a 350?
    Please help if you can.
    Thanks.
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    Look in user manual C350 Printer Controller for specifics on setting SSL.
    It can be found easily under the network tab of the pagescope interface.
    ---Groucho Marx
    • herdless
      • Aug 2010
      • 10
      This machine is a Bizhub 350 B/W not the C350. If it's in the manual, I can't find it. I've spent probably 2 hours looking at the manual for this - can't find it.
      • Hansoon
        • Sep 2007
        • 3383
        Does this help you somehow?
        From Minolta:
        Solution ID TAUS0701612EN* Solution Usage
        Description
        When setting up scan to E-mail, there is no field available to enter the SMTP host name.
        Solution
        CAUSE: DNS settings have not been entered as the DNS option is disabled. The machine will not allow host names without DNS server information for host
        name resolution.
        SOLUTION: Enter the Admin 2 mode, select network settings, then DNS settings. Set the DNS server address and enter. Now enter the SMTP settings and
        the field for the host name will be available.
        SPECIAL NOTE: Solution contribution by Mike Galletta, Workgroup/SSD
        or this:
        Enabling User Name and Password for SMTP Authentication.
        Solution
        SMTP Authentication
        Note : Before starting, make sure NC-4 and SU-2 or SU-3 are installed. ROM versionmust becurrent.
        1. Login Admin mode onMFP panel.
        2. Select Admin2.
        3. Open "SoftSW setting" and set "SoftSW 380, Bit6=1 and Bit2=1".
        4. Save Settings.
        5. Open "Network Set" and "SMTP Setting".
        6. Set SMTP Server Address (TCP/IP address of Mail Server).
        7. Set "E-mail Address"
        8. Set "SMTP AUTH User Name"
        9. Set "SMTP AUTH Password"
        10. Save Settings.
        Note : If you get error code EA21C6, it means Authentication method error. If you get error code E72217, it means User ID or Password is incorrect.
        WithSU-3:
        If you want to share POP3 User name and password as SMTP Auth User name and Password, set "SoftSW 380, Bit6=1 and Bit2=0".
        Set the POP3 user name and password on "Network Set" and "POP3 Setting".
        This method will use CRAM-MD5, Login or Plain authentication.
        CAUTION : If you set SoftSW 380, Bit6=1, URL report function with Scan to Server (FTP), HDD will notwork.
        SPECIAL NOTE : Solution contribution by Cesar Jimenez, Production Print/SSD
        Hans
        • Stirton.M
          • Oct 2009
          • 1804
          my bad....sorry....
          Biz350 SMTP over SSL TSB/TAD....
          Subject:
          Does this MFP series support SMTP over SSL/TLS?
          Description:
          Does MFP series support SMTP over SSL/TLS?
          Solution:
          The bizhub 200/250/350 and 222/228/362 specification does not support SMTP over SSL/TLS.
          An alternative you may be able to use is SMB scanning or scan to user box. SMB is preferable due to ease for end user. User box is a little more to it, but just as viable. Then the user can manually forward the attached file through their desktop email.
          ---Groucho Marx
          • herdless
            • Aug 2010
            • 10
            I was afraid this was the case. I already have SMB scanning set up but this woman isn't happy with it because she "can't ever remember how to attach a file to an email"!! Thanks for the info.
            • mansart
              • 852
              This may be a solution for you
              Alternative SMTP option for use by SSL deprived network devices? - Google Apps Help
              • herdless
                • Aug 2010
                • 10
                I think this woman is going to have to learn how to attach a file to an email.
                • Stirton.M
                  • Oct 2009
                  • 1804
                  "Kicking and screaming, get yourself into the damn 21st century for crying out loud...."
                  There is quite literally no excuse. She wants the convenience, then buy a new machine that is capable of SSL or tell her IT to get over themselves with security and disable SSL for SMTP.
                  ---Groucho Marx
                  • Hansoon
                    • Sep 2007
                    • 3383
                    Perhaps I don't get it and do not understand the quintessence of the post, but is scan-ftp not an alternative or is this too unsure for that IT chap?
                    Hans
                    • Mr Spock
                      Vulcan Inventor of Death
                      • Aug 2006
                      • 2064
                      Hans
                      Hans if I have read all the post correctly they want scan to email because the end user does not know or want to know how to attach a document in her email program.
                      • acsolutions
                        • Jun 2010
                        • 519
                        i would just create a dummie google account to use as her "mail server" then justadd he email as a new registration
