info !!!!!!!!!!!!!
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    info !!!!!!!!!!!!!
    Hello everyone I'd like your opinion on this question a client asked me:
    are there any canon or other copier brands connectable with wireless?
    Thank you and I await your answers.
    BEST TECHNICIAN . NICE PEOPLE .
  • nmfaxman
    • 1702
    Use an Access Point device or a wireless gaming adapter.
    Works on all network equipment.
      • 23008
      Agreed. You don't want a wireless router. You want a Wireless Bridge or WAP.
      • zaza
        MECANOGRAPHE
        • Mar 2008
        • 1095
        ok guy but ..this solution in all brand of copiers ..?
          • 23008
          Anything with an RJ45 live network connection. =^..^=
          • zaza
            MECANOGRAPHE
            • Mar 2008
            • 1095
            yes ...RJ45 ...but ..all brand of copiers can work in wireless ?
              • 23008
              The MFP can't tell the difference. There is a Cat5 cable from the WAP to the printer/MFP. The print data is indistinguishable. =^..^=
              • Eric1968
                • 2458
                Some machines have a wireless network card as an option. Then you don't need any UTP-cables. But not all machines have that option.
                • Jules Winfield
                  • Jul 2009
                  • 821
                  The wireless ethernet bridge is the way to go. It basically turns a wireless connection into a wired connection. As far as any printer or MFP is concerned it is a wired connection. No special settings are required on the printer/MFP end.
                  But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
                  • zaza
                    MECANOGRAPHE
                    • Mar 2008
                    • 1095
                    well l think in ricoh copiers it have only this wireless network card ?
                    • mrwho
                      Major Asshole!
                      • 4299
                      When using a wireless adaptor or wireless bridge on the RJ45 port of the machine, the machine sees it as a regular wired connection, so it works with any equipment (copier, printer, scanner, desktop, laptop, netbook, PC, Mac, etc) that has a regular RJ45 network connector.
                      Maybe Google Translator can explain it better to you.
                      Mascan42
                      Ibid
                      • KenB
                        Geek Extraordinaire
                        • Dec 2007
                        • 3944
                        Run the other way from MFP wireless cards - they're mostly bad news - not to mention the price difference.
                        As my fellow members have added, a bridge is the way to go.
                        • zaza
                          MECANOGRAPHE
                          • Mar 2008
                          • 1095
                          friend mrwho thx lot for your better explain ...here you learne the fonction of wireless as other machine ..copiers or printers or others ..yeah the bridge is RJ45 ...well..then all network copiers for any brand can work in wirless ..it's clear..
                          • RRodgers
                            • Jun 2009
                            • 1947
                            Ricoh does sell a "kit" but... that was a while back. I don't know if they do it anymore. I believe KonicaMinolta will have a Bluetooth kit that you can install. But, the wifi bridge will work on all of them. I use it all the time in OLD churches that we can run ether for.
                            • kingpd@businessprints.net
                              • 921
                              Would something like these work?
                              Newegg.com - wifi bridge
                              Does anyone know the difference then, if any between a wifi bridge and those things called wireless print servers?
