bizhub 350/250 connectivity
  • aleksander
    • 378
    Hi all
    I tried to connecting bizhub 250 to the network using UTP straight and setup the IP address for the MFP. Then I ping both from MFP and PC, both of them replied. No problem.
    When I try to open the PSWC, it takes at least 20 sec to open the web connection. Then I try to do print test page, not succeed. I see the memory free 99% and (!) mark displayed. But no test page printed.
    Then I tried using UTP crossover directly from my notebook to the MFP. No problem for printer and scanner function.
    Anyone know the solution? please help me.
    Thank you.
  • mrwho
    Major Asshole!
    • 4299
    There's something wrong somewhere between the MFP and the switch - could be the UTP cable, the wall connector, the wall cabling, etc etc etc.
    Try to lower the MFP network speed to 10Mbps Half-Duplex, sometimes it solves the problem for me. But ultimately the best solution is to pinpoint the problem in the network and solve it.
    Mascan42
    Ibid
    • Hansoon
      • Sep 2007
      • 3384
      Had once a similar experience. Found never the reason but used a workaround mentioned by a colleague in this forum. He suggested to hookup the MFP through an extra switch just behind the machine and this is working since more than a year now. The network is very large and complex with several segments. Almost impossible to find the real cause but that trick works well.
      Hans
