Sharp AR-M160
  • bushcrafter
    • Feb 2011
    • 6
    Sharp AR-M160
    Hi Guys,
    I have an AR-M160 that is supposedly taking down the customer's network after a power failure. This has happened on more than 1 occasion apparently, and they reckon that they unplug the device and the network is then ok.
    Anyone had any experience of this?
    Every connection leaves a trace.
    • 23009
    Never in 10+ years of networked machines have I heard of this, on any make.
    It's not impossible, but highly unlikely. It should be easy enough to prove. Can you connect via crossover cable to your laptop, then maintain a network connection, print, etc.? TCP/IP, yes? =^..^=
    • bushcrafter
      • Feb 2011
      • 6
      UPDATE:
      Turned out to be that the device was set to DHCP, and was picking up the server's IP address.
