This may be an easy fix for someone who already knows but we're in the dark here as to how to go about resolving this issue.
This all pertains to SWS2 (the most recent web interface for all Samsung MFPs - the one with the purple bar at the top and admin/sec00000 login). The older style web interface works.
Trying to set up scanning to a shared folder on Windows 7 to no success. The error message on the display when attempting at the copier is "Network Error" and the error message on the web interface when hitting test returns "Operation Fail" during the second step, trying to login.
Steps I have already taken:
*Duplicated this problem at our shop as well as the customer in need
*Tried several models of Samsung, including an 8540, two 6545s, and one 6250 all running latest firmware with the SWS2 web interface - not a lemon/board issue
*Tested those same copiers on Vista and XP computers to great success - it is Windows 7
*Made sure copier's IP settings are on the network using ipconfig /all and duplicating IP/DNS settings
*Attempted scanning using IP address instead of hostname
*Ensuring shared folder is shared with the correct permissions.
*Tested scanning to the folder with another manufacturer (successfully).
*Ports 139 and 445 both tested to be open using other manufacturer's machines as well as using the free software AdvancedPort Scanner.
*Uninstalled all Spyware/Anti-virus and disabled Windows Firewall
*Attempted what feels like every possible setting in SWS2
*Triple, Quadruple checked possible spelling mistakes
I left a message on our rep's voicemail, but we have received limited support from the factory in the past, and so I am turning anywhere for help. This seems like a potential catastrophe if we start upgrading firmware or seeing more Windows 7 machines.
