Bizhub 363 Scan to email
  • cadkins
    • 34
    I have a customer that has a BH363 and we were setting up scan to email through their 2003 Exchange server.
    The scan errors out with the description "Forward TX Error". What does this error mean? Looking through the tech site, it says that this is caused when authentication is turned on and is not needed. However, we didn't have authentication on to begin with.
    We used multiple accounts that are valid. We tried SMTP authentication, we turned it back off, nothing worked. Logs of the exchange server didn't show anything being rejected.
    We did set up LDAP and it did find the email address and such just like it should, but still nothing. So I know the settings are correct. We tried the IP of the exchange server, we tried the host name. Nothing changed.
    Any suggestions???
    Thanks in advance!
  • richd
    • Aug 2009
    • 49
    Is relay turned on in the exchange settings ?
    • cadkins
      • 34
      Re: Bizhub 363 Scan to email
      yes
      • jeffreyclay
        • Sep 2008
        • 43
        Setup an account on the mail server for the copier to make it a known user to the network.
        • cadkins
          • 34
          We tried that as I stated that in my original post.
          • Mr Spock
            Vulcan Inventor of Death
            • Aug 2006
            • 2064
            Setup an open relay for the copier's ip address in exchange. This is different then logging into the server to send the emails. Also if the exchange is not seeing any activity then the copier is not seeing the server.
            • cadkins
              • 34
              we have already added the machines IP to allow it to relay through the Exchange server.
              The machine is seeing the exchange server because we also set up LDAP to test and it worked just fine. Pulled back the info with the users and email addresses and such.
