print problem with ricoh 3035
  • z_ming
    • Jul 2011
    • 31
    i've been encounter the weird problem with ricoh 3035 . driver installed on win2000 server
    (member server). nearly 60 clients share the printer. erveryday it output a lot of misprint
    paper (just a line of unreadable code). i have to reatart machine ,stop print spool ,and
    delete print queue , otherwise it keeps running out of paper .
  • Canonguy123
    • Feb 2011
    • 18
    Re: print problem with ricoh 3035
    Sounds like you are using the postscript driver without postscript on the machine.
    • rthonpm
      • Aug 2007
      • 2859
      Definitely a driver issue. Try adding the Win 2000 driver and then add additional drivers for the workstation clients trying to access the machine in the Advanced tab of Printer Properties. That way each machine gets the specific .dll files for the operating system to properly send the print job.
      If you're using the PostScript driver, like Canonguy said: make sure the PS card is installed on the machine. If not, replace the driver with PCL 5e or RPCS.
      • copyman20
        • 207
        Had issues like. it would print fine, than all a sudden it starts to print gibberish. turns out to be either a firmware, or bad RAM.
        • z_ming
          • Jul 2011
          • 31
          in this case there isn't any PostScript driver.i've tried rpcs and pcl 5 but it's unsucessful
          i'll try pcl5e . hopefully ,it can be sucessful.thanks for your tips
