Windows 7 Pro Shared Folder
    • 8197
    I set up a shared Folder on the C: Drive. I believe I properly constructed it with Full Control to Everyone on both the Share and Security tab. I can see the folder as being shared when I hover the mouse pointer over it.
    On the Network view from other PCs in the office, Win 7 PCs can see the Share but Win XP Pro SP3 computers cannot. Any ideas?
  • mojorolla
    The Wolf
    • 2609
    Re: Windows 7 Pro Shared Folder
    Try adding the "Guest" account to the security tab. You could also turn of UAC to test.
    • copymech
      • Sep 2011
      • 196
      I read a how to article, It said to create a shared folder in the public folder of the win 7 machine.
      • TheOwl
        • Nov 2008
        • 1732
        On the XP SP3 machines, are you going through the My Network places?
        If so, it could be that the XP machines are on a different workgroup.
        Another thing to try on the XP SP3 machines is to use the UNC path directly to the share on the Windows 7 machine ie. \\Hostname\Sharename . Also check your advanced sharing settings with Windows 7 by going to the Network and Sharing Center and you may find adjustments for the type of networl you have joined (wheather be Home, Work or Public).
        • rthonpm
          • Aug 2007
          • 2853
          Go into the network and Sharing Centre, then the advanced sharing settings. Find the network type your computer is using and then look for the File Sharing Connections setting. Try changing the setting from using only 128 bit encryption to using 40 or 56 bit encryption. You may also want to try turning password protected sharing off.
            • 8197
            All good hints to try next week. Thx!
