Scanning to Email with Exchange
  • TheOwl
    • Nov 2008
    • 1732
    We have all at some stage had problems with machines scanning to email or sending notifications when Exchange is involved. More than a question post, this more of a how to post.
    Most SMTP problems could be gotten around by using a whitelist in Exchange 2003, but not 2007 and 2010 are slightly different. The attached document describes how to add a Receive Connector in Exchange which allows for un-authenticated SMTP Relaying. The good thing about this though is that the SMTP Relay Connector is locked down to just certain IP addresses which would be your devices and not the PC's which helps IT people say yes.
    Anyway, hope this helps.
    Email with Exchange 2010.pdf
  • JSC
    Gimp
    • Dec 2006
    • 618
    Re: Scanning to Email with Exchange
    Nice one!! thanks.
    The gene pool could use a little chlorine.
    • CanonSco
      Man About Town
      • Jul 2010
      • 368
      Thanks.
      Yes, I am a nerd.
      Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
      • TheOwl
        • Nov 2008
        • 1732
        If anyone is getting errors with Exchange 2007 SP3 when trying to add the connector, please check out this Microsoft KB aticle:
        You cannot create a receive connector after you install Exchange Server 2007 SP3
        Read through the article which tells you how to get around the issue.
          • 22927
          Kudos to Owl. He's pulled me out of several of these situations. Many thanks! =^..^=
