Ricoh spc410 B&W priority
  • Butrus
    • Jan 2012
    • 115
    Hi,
    have set default seting to black and white
    But only when colour PDF files are printed switches itself automaticly to Colour
    All other file types are printed in b&w
    Can this be changed?
    Thanx!
  • luke001
    • Dec 2011
    • 46
    Re: Ricoh spc410 B&W priority
    Which driver You use ? PCL or PS. PCL 6 can by modified via Printer Driver Editor.
    • Butrus
      • Jan 2012
      • 115
      Driver is RPCS
      • luke001
        • Dec 2011
        • 46
        Try the last firmware. I still ask my colleagues.
        • Butrus
          • Jan 2012
          • 115
          Nobody?
          • rthonpm
            • Aug 2007
            • 2849
            Are you using full Acrobat or Adobe Reader? Also what version(s)?
            • Butrus
              • Jan 2012
              • 115
              Adobe reader X
              • luke001
                • Dec 2011
                • 46
                Colleagues have no idea. Try to print via Foxit reader.Or using PCL6 driver what happens
                • rthonpm
                  • Aug 2007
                  • 2849
                  If it's the latest version of the Reader, it can override the defaults set in the driver. Try double checking all of its settings. I had an issue where Adobe's settings were printing files duplex, even though single sided was set in the driver.
                  Sounds like you may be running into something similar
                  • Butrus
                    • Jan 2012
                    • 115
                    Where in Adobe Reader X are those settings?
                    I searched but with no success...
                    Thanx
                    • rthonpm
                      • Aug 2007
                      • 2849
                      File
                      Print and then the dialogue that opens up...
                      • Butrus
                        • Jan 2012
                        • 115
                        OK,
                        I knew that...
                        I want this printer to print in B&W as a priority all document files
                        Not to print all document files in B&W and only PDFs in colour as a defoult
                        • wimps
                          • Mar 2012
                          • 16
                          When you go to the print preverances in the driver properties, you must set it to B/W and "apply" otherwise the settings will not take place, you could also look at the page setup and see what it was setup for as default!
                          Hope it helps
                          • KenB
                            Geek Extraordinaire
                            • Dec 2007
                            • 3944
                            Seven months later????
