Hi all,
I was wondering if there are any techs out there running network fax drivers on a fairly large scale network infrastructure.
The issues we're having is Windows 2008 R2, and about 80 Windows 7 64bit workstations shared drivers from server.
A Taskalfa 520ci with fax card.
Now printing is fine using the KX drivers 5.3.
Once network fax drivers (v3.8) are installed and shared, the print spooler will freeze. Once removed the printing has no issues.
second scenario:
Windows 2008 R2, being used as a RDP host. So essentially 1 driver for printing.
Again, once network fax drivers are installed print spooler crashes.
I've suggested running the fax driver in isolation mode to see if that made a difference but does seem the network fax drivers may be conflicting the print?
The problem is definately isolated to the network faxing as once removed, printing resumes without errors.
So again, anyone had any similar abnomalies?
THanks
second scenario:
THanks
